rebuilding 700 r4 what clutches
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
here is my list of goodies for my 700 r4 rebuild
Transgo SK700 Junior Shift Correction Kit
700R4 Hi Performance Red Lined Power Band 2 5/8" Wide
Transgo TH700-R4, 4L60E Corvette Style 2-4 Servo Piston
700R4 .500" Diameter T.V. Boost Valve & Sleeve 1981-ON.
700R4, 4L60E Thrust Washer Kit.
700R4, 4L60E 1-2, 3-4 Accumulator Piston, 1.989" Outside
Diameter, .308" Pin Size.
TH700R4 Intermediate Boost valve .300" diameter
Transgo HI-REV TH700R4/4L60E/TH2004R High RPM Pump Vane Ring Kit 1980-ON
Transgo 700R4, 4L60E HI-RPM 3-4 Clutch Spring Kit 1981-ON.
77966-94MK 700R4 Performance Throttle Valve Plunger & Sleeve Kit
TH700R4 Alto Hi Energy 3-4 9 Clutch Pack
I have Lined Up Clutches From Largest To Smallest. Going From Left To Right I Know That The Middle Set Is 3-4 Clutch Pack & The Absolute Last Ones Are The Overrun Clutches. Can Anyone help Me Identify The Rest? Another Question, Are There Better Clutches Than The Ones I Have Pictured?
Car: 1988 IROC-Z
since i couldn't edit for some reason...
i also have a BW 29 Element Sprag That Is Going In It
the clutches i have pictured besides the 3-4 clutch pack are stock borg warner frictions.
Car: 1988 IROC-Z
Well i guess they are no better clutches for the other "gears". Well other than the 3rd clutch pack and 2nd 2-5/8" Red Alto Band.
the fourth clutch pack sucks ***. there has got to be something better especially since i want to go WOT in 4th gear.
Please Help!!!!
Please Help!!!!
The 3-4 clutches are "on" when you go to 4th gear. The 2-4 band is coming on to make the 4th gear shift. The Trans-Go Junior is not enough as it is. I can help you out on this, just give me a call after 11am PST at 800 7763288.
Car: 1988 IROC-Z
thanks for clearing up my misconception. i will be calling you tomorrow. thanks again.
thanks for all the advice on the trans build up. dana is a very helpful and courteous person to talk to. i hope all goes well.
here's the list of the stuff i already have. please make the kit minus the the stuff i already have listed. (Cheaper)
.500 TV Boost Valve
.300 Intermediate/Reverse Valve
2-4 Corvette Servo
3-4 High Energy 9 Clutch Pack
29 Element BW Sprag
SPX The Beast Sun Shell
Hi Performance Red Alto 2 5/8” (Thick) Band
Performance TV Valve/Sleeve For 3-4 Shift
Transgo Hi RPM Pump Ring Kit
Transgo Hi RPM 3-4 Return Springs
New Thrust Washers
New Thrust Bearing Kit
New 1–2, 3–4 Accumulator Pistons
New Pump Vanes + Guide
New Stock BW Frictions + Steels
.500 TV Boost Valve
2-4 Corvette Servo
29 Element BW Sprag
New Thrust Washers
someone972
Aug 30, 2015 12:52 AM
