paddle shifters
paddle shifters
has anybody seen or installed the shrifter paddle shift system in there third gen.it looks pretty neat, the only dowside i see is you need a 4l60e or 4l80e transmission,other than that it looks like a lot fun on twistie roads which are everywhere around here.
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
You don't necissarily need a 4L60E/4L80E. You could do this with a T56 too. The Aston Martin Vanquish uses a paddle shift T56. Bob Hanlon saw a test car that was a Ford Mustang fitted with the paddle shift system from an AM at Fords R&D facility.
This is an incredibly intensive system. The computer side makes it nearly impossible for all but an electrical engineer, and even then you'd need significant programming ability. I don't think the average, or even above average car crafter is going to brew up a paddle shift 3rd gen in their garage. This is somethign that only an OEM with their limitless R&D budgets can make work.
On the flip side I guess you could rig up something with a full manual valvebody 700R4. The 4L60E is a problem again because of the electronics.
Car: `86 SS / `87 SS
