t56 reverse lockout solonoid. part #
Old Jun 9, 2005 | 10:14 AM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
Im trying to find a pigtail.. a replacement connector. something so i can wire up my reverse lockout solonoid. anyone point me in the right direction?
Old Jun 12, 2005 | 02:48 PM
DracoZK's Avatar
Car: Z28
Engine: 350 L98
AC Delco 12101857 - is the pigtail. Just bought one the other day.
Also has a PT249 on the label.
Kyle
Old Jun 12, 2005 | 08:09 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
thanks. I called the dealer.. they want like $30cdn for it.. !!! I took one of the connectors that i cut out of my harness and it was the same shape but didn't have the grooves cut in the side.. so i ground the sides down.. worked like a top. but i have that PN written down.. just in case
thanks
Old Jun 13, 2005 | 06:59 AM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
Price of the GM pigtail is pretty high.
For my VSS I was able to use the same connector as the temperature sensor connector (on the manifold). It fits perfectly.
Which sensor connector did you get to fit the Reverse lockout?
I am right in the middle of an install---
Thanks,
S-D
Old Jun 13, 2005 | 07:16 AM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
not entirely sure which connector i used as it was just in a box.
but what i deleted from the harness was the crank pos sensor, and all the smog stuff.. what i did to get the plug to work was to grind down the sides about 1/16" on either side.
I actually had the right connector but it didn't have any pins in it so i duplicated it.
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
hokis
Aug 9, 2015 03:57 PM
1nastygta
Aug 8, 2015 07:38 PM
