Ford 8.8
Old Jun 22, 2005 | 05:54 PM
ZQ8Dude's Avatar
Ford 8.8
Has anyone thrown one in a 3rd gen?
they are extremely common and only marginally weaker then a 9"
Old Jun 22, 2005 | 06:29 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
Yes, its been done and someone , not a company, was building them to order...or at least that was the plan.
I believe his screen name is "87roc_t56"
search for his name and you should be able to find the post
edit: brought it back from the dead for ya
Old Jun 23, 2005 | 12:59 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Yeah, the 8.8 is a decent rear. They tend to eat up bearings and the gearset on high milage units though. If you buy one used plan for a complete rebuild. The stock Ford limited slip leaves a bit to be desired too. I'd go with an Auburn or an Eaton instead. Also, upgrade the axels to 30 spline (28s are stock) if you plan to run the car hard. Definately replace the axel bearings too. If you want to get away from the c-clips get a set of weld on housing ends that use 9" bearings and retainers. C-clip eliminators are a band aide fix. They will leak when used on the street, and the bearings are smaller than the stock ones.
Old Jun 23, 2005 | 01:07 PM
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
Mongoose462ci
Sep 16, 2015 11:46 PM
