no bleeder fitting on my clutch--Help
Old Jun 28, 2005 | 05:42 PM
andys86ta's Avatar
Car: 1986 trans am
Engine: 300hp 355cu. inch
Transmission: 350 turbo with shift kit and ratchet shifter
I have a t5 tranny in my 86 bird and it has the origional master/slave assembly. I would like to drill out the restrictor in the line by the emaster cyl. but i can't find any instr. on bleeding it without a bleeder screw. Good luck with this one.
Old Jun 28, 2005 | 06:11 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
what restrictor? there is a small allen screw in the slave (this is how you bleed it)
Old Jun 28, 2005 | 06:28 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Well if its out of the car kind of hold it up like how it would sit in the car but point the slave in a 45* down and have someone start pumping in its full range of motion slowly untell it's nice and firm.
Old Jun 29, 2005 | 04:41 AM
andys86ta's Avatar
Car: 1986 trans am
http://www.installuniversity.com/ins...sity/index.htm
They used a new master cyl. but that is the restrictor inline o keep the fluid from moving quickly like it should. A stupid idea from GM.
Old Jun 29, 2005 | 09:38 AM
firebirdjones's Avatar
restrictor
Yep, GM incorportated the restrictor in the clutch line, I know of in the 4th gen cars anyway, in order to soften the clutch engagement for drivers that like to pop the clutch. I believe GM did this to crutch a weak drivetrain to keep the parts breakage down. GM knows the 7.5 rears are weak and a decent V-8 with a stick will scatter it in short order, it was cheaper for GM to soften the clutch engagement with a restriction in the line than it would be to fix the real problem and put a decent rearend in these cars Larry.
Old Jun 29, 2005 | 09:44 AM
just to add
Just for the heck of it, here is another tid bit of useless knowledge I have, I also know in the 4th gen cars with the automatics, GM incorporated something in the tuning to pull timing out everytime the auto upshifts to another gear at full throttle, again to soften the load on the drivetrain and keep warranty claims down. GM is really scared of those 7.5's coming back to haunt them Larry.
Fronzizzle
Feb 9, 2017 09:31 AM
New2Chevy
Sep 28, 2015 12:35 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
BOOT77
Sep 5, 2015 03:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
