Installing rear end....what needs to be done?
Old Jul 10, 2005 | 10:28 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
I have a complete 3.42 posi ready to go into my '91 TA. While it's out should I put in new fluid or anything? Grease anything up? Also, are the springs going to need to be removed and recompressed or does the rear do that?
I've never done one of these but I do work on my cars. Are power tools necessary?
Old Jul 10, 2005 | 11:28 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
I would change the fluid and put fresh LSD fluid in as well. Check the brakes for wear. The springs just naturally compress you put the rear in place and bolt it up.
Air tool are nice but not necessary, I've done both of my swaps without. But I think next time I use a bay at work.
Old Jul 11, 2005 | 04:10 AM
CrazyHawaiian's Avatar
Car: too many ...
I like to sand/prep/paint stuff while I have it off the car but thats really up to you. I'd definately change the fluid and posi additive. Also consider changing the E-Brake cables if they are stretched or worn, and check the bushings on the components that attach to the rearend (LCA/Panhard/Etc) and consider replacing them while everything is appart (order bushings first, drop old rear, take the parts to have bushings pressed in, then re-install everything). No need to compress any springs. If you are planning to swap any rear suspension parts now would be the time to do it.
Old Jul 11, 2005 | 11:39 AM
Car: 1994 Trans Am
So this would be that time, eh? I would love to lower this thing 1.5".
So I need 2 lubes for the back? Which one goes where?
Old Jul 11, 2005 | 04:42 PM
SLAYER6669's Avatar
Car: 1991 Camaro Z28
Transmission: T56 6-Speed
I just did mine also, and while I had the rear out, I pulled off the exhaust and took the gas tank down and replaced to fuel pump to avoid that problem in the future (105k on the motor). No better time to do it than while the rear is out! As for the rear swap, its not really all that difficult to do.. Air tools will help with bolts that haven't been removed in forever, but as said its not necessary.. Just soak the bolts ahead of time with PB blaster if you're going to be wrenching away..
Old Jul 11, 2005 | 05:16 PM
Car: 1994 Trans Am
PB blaster is it a spray, can I get it at AutoZone?
Old Jul 12, 2005 | 11:32 AM
Car: 91 Camaro RS
Yes, PB blaster is a spray. You can get it every auto parts store, most hardware stores, and large general stores.
Old Jul 12, 2005 | 12:51 PM
Car: 1994 Trans Am
Approx, how many bolts are there. I counted 6-8. Minus driveshaft and that kinda stuff.
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
I'llrocya
Feb 2, 2016 11:43 PM
hectre13
Aug 26, 2015 08:17 AM
