T-5 Tranmission
Old Jul 13, 2005 | 11:28 AM
FBoDyV85's Avatar
Car: 89 IROCZ Camaro
Engine: 350 w/ Boltons
T-5 Tranmission
I have a stock 350 w/ 700R4 trans and want to make it 5 speed. Is the swap hard? and will the stock camaro rear end hold up? up for suggestions.
-steve-
Old Jul 13, 2005 | 03:39 PM
83BlackBeauty's Avatar
Car: 83 Trans Am
Engine: 5.7 (350) TPI
Transmission: soon to be 700r4
Axle/Gears: 9-bolt rear. gears? hell if i know
All I can say from experience is make sure you get a newer used one with low miles or a recent rebuild. Im surprised my T5 is still going Im getting used to the grinding the transmission makes lol
also just try not to drop it in gear at too high of an rpm or race with it. it will blow T5's can't handle torque thats why GM never bolted them to the 350
Old Jul 13, 2005 | 08:33 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
The swap is not to bad it's finding all the parts you will need . A non W/C is the older one , the newer one is in 88 and above cars. The w/c class one would be much better to get . The rear is a touchy subject some people beat them up for ever, they say . My first t-5 and rear lasted 3 months with the 350 but I drove it like I stole it speed is addicting . You can have many happy miles if you get on it in the higher gear's . If you have the money and the know how I say go for it .
Old Jul 15, 2005 | 12:25 AM
weberflorida's Avatar
Car: 1991 Camaro Z28
Dude I definitely think you need to do the swap. It can be done very cheaply. But like the other dudes said make sure you get one low miles or recent build. Or hell go pull one out of a junkyard and get it rebuilt.
Old Jul 15, 2005 | 06:06 AM
CrazyHawaiian's Avatar
Car: too many ...
I'm getting ready to do the swap soon. First I went from 700R4 to TH350, now I'm gonna go T5. I got all the swap parts I needed for free by buying a T5 parts car and parting it out. Definately go with a freshly rebuilt tranny if you're gonna drive it hard. Might even want to consider some upgrades on the rebuild. I'm gonna be doing crazy stuff with this car (car in sig) so I upgraded the rebuild to some tougher internals.
Old Jul 15, 2005 | 09:57 AM
Yeah Crazy is right definitley upgrade some parts. I am going to have mine built by tko performance. He says then it should be good for about 450ft/lbs. That is more than i will ever need so hopefully it won't need a rebuild for a long time.
Bill
Old Jul 15, 2005 | 02:45 PM
grove's Avatar
Car: 1988 firebird
Engine: 305 tpi
Transmission: 95 T56
Axle/Gears: stock 10 built, yukon diff, 4.10
the swap takes about 2 days if you have all the parts. the hardest part i thought was putting in the pedals. need to brake your arm in several places. oh the bellhousing can be separated from the tranny. i didnt know this and had a pain putting the tranny on with the bellhousing. oops. make sure you get the right flywheel to. that was another oops i did.
Old Jul 16, 2005 | 04:57 PM
92RS3.1L's Avatar
Car: 91 Z28
Engine: Rebuilt and modified 350
Transmission: rebuilt T-5
Yes, get the tranny rebuilt! Make sure you use HI performance parts. I bolted my T5 behind my 400rwtrq 350, and it blew in about 3 weeks!
Old Jul 16, 2005 | 05:30 PM
NuBird's Avatar
Car: 86 Transmaro, yes I'm for real do a
Engine: 383, 4 bolt block, scat crank, PM r
Transmission: t5 NWC and its holding up behind my
Axle/Gears: 9 bolt aussie, 3.73s from yukon gea
7986708936 that is the item number on ebay, its my auction. Its a WC T5 with everything, check it out if you don't mind cause I need the money to rebuild my 700r4. Anyone on here know how to rebuild em? i have the kit I just need someone to pout it together, I'm in the louisville KY area
PurelyPMD
May 5, 2016 04:57 PM
Zane Story
Oct 8, 2015 12:40 PM
luvofjah
Sep 26, 2015 08:28 PM
DARKmj16
Sep 9, 2015 04:07 PM
Formula_88AE
Sep 3, 2015 01:47 PM
