t-56 clutch question
Old Jul 20, 2005 | 06:55 PM
5.7Camaroboy's Avatar
Car: 85Z28
Engine: TPI355,383LT4
Transmission: 700-R4,T-56
I did a search and couldnt find anything i know this topic has been covered but im getting ready to put my t-56 in the moter is just a 350 2 piece rear main seal what do i need to get to still use the clutch flywheel on the lt1 when i put that in. whats different is it the flywheel or the clutch.? thanks chris
Old Jul 24, 2005 | 01:47 AM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
the difference is gonna be the flywheel. 2- piece RMS flywheels have a much larger center bolt pattern to the engine than a 1-piece RMS (about 3/8" diameter differece). but this is just the hole in the middle. the clutch and everything else will bolt right up to either flywheel, as long as they have the same number of teeth.
Old Jul 24, 2005 | 05:51 PM
Car: 85Z28
thank you thats what i thought so i just need an lt1 clutch and it will work on either flywheel what is the tooth number on the flywheel i need i think its what 153 or 164 or something. thanks chris
Old Jul 24, 2005 | 06:07 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
The LT 1 flywheel is completely different. I'm not sure if anyone makes one for a two piece crank.
Old Jul 24, 2005 | 08:19 PM
Car: 85Z28
i know they do or how could people use the old 2 piece rear main seals theve been installed in some old cars,they only other way would to be to change the bellhousing and clutch setup and i dont see why you would bother
Old Jul 24, 2005 | 08:24 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Here ya go:
http://www.jegs.com/cgi-bin/ncommerc...37&prmenbr=361
183-700107 Camaro/Trans Am w/93-97 6-Speed w/Engines Manufactured Before 86 (2 Piece Rear Main Seal) Exc. 400/454, 153 Tooth, 35.5lbs, Steel $349.99
Old Jul 24, 2005 | 08:26 PM
Car: 85Z28
ahhh ha i knew they did well thanks for the link.
now i gotta 2 decide i really dont want to buy two flywheels dangit.
87 camaro iroc
Aug 20, 2015 07:47 AM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
cRoe4
Aug 7, 2015 08:46 PM
rsrmoore
Aug 7, 2015 08:44 PM
