is this bad
Old Jul 25, 2005 | 09:52 PM
camaro86's Avatar
Car: 91 z28
Engine: 350 tpi
is this bad
is it bad to have your auto trans in the D with the circle around it all the time when you go and drive it?
Old Jul 26, 2005 | 03:31 AM
BRobinson's Avatar
Car: 82 Camaro
Transmission: TH-350
Axle/Gears: 3.08
No. It's ok. That would be overdrive. Where your torque converter locks together at a certain speed or gear to help increase gas mileage. It is a completely automatic thing.
Old Jul 26, 2005 | 08:32 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
if your not out on the highway you can get a little less wear on the trans by keeping it in drive instead of OD. Its a straight pass through with the 1:1 ratio.
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
dimented24x7
Sep 17, 2015 06:58 AM
gta892000
Sep 16, 2015 12:40 AM
