Swapping t-56 for t-5
Old Jul 26, 2005 | 02:11 PM
mike88form350's Avatar
Car: 88' Formula 350
Engine: 358 ci TPI
Transmission: Tremec T-56
I'm thinking of swapping my tremec t-56 out for a g-force t-5. Any opinions? I'm kinda conflicted about it.
If I take the t-56 out I will be selling my t-56 swap set up:
Spohn torque arm and crossmember
Spohn driveshaft
and 5-56 trans w/ adaptor plate and shifter
anyone interested?
Old Jul 26, 2005 | 07:58 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Why would you go from a T56 to a T5? That is like going from Pamela Anderson to Rosie O'donnel. The T56 is superior in everyway.
EDIT: You said G-force and not WC. I am sorry. None the less I would stick with the T56. You can run steeper gears with the crutch of the second OD to maintain some fuel mileage. Even the weekest of T56's were rated at 400 to 450lbs+ TQ of abuse. I would keep what you have.
Old Jul 27, 2005 | 06:53 AM
terrynot's Avatar
What are you asking for the T56?
Old Jul 27, 2005 | 12:43 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
The LT1 F-body T56s were rated at 450 lbs/ft., except some '93 versions with a very tall 1st gear which only got a 350 lbs/ft. rating.
The G-Force T5 is rated to 600 lbs/ft. and 500 hp. It's a stronger trans.
The 6th gear in the T56 is a gas milage gear only used on the highway. Trust me, it isn't that useful. At 80MPH with 3.73 gears my car turns 1,900 RPM. At lower speeds you are just lugging the engine and beating the bearings to death. Typically I only use 1-5 when cruising around.
For performance the G-Force T-5 is a better trans. For all around cool factor and slightly better milage the T56 wins. It just depends on what you want. I will say this for the T56: when people look into my car they always exclaim "Oh cool, it's a stick!" Then I say, "Yeah, check out the shifter". They notice the pattern and say "Is that right? It's a 6-SPEED?!" Then I just say "Yup. T56." They just stare mouth agape.
I wouldn't mind taking the Spohn stuff off your hands. Let me know what you'd want for it. BTW, I assume you have an aftermarket T56 since you mentioned an adapter plate. Is that correct? I'm running an LT1 T56, and I think the parts may be different.
Old Jul 27, 2005 | 01:30 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Don't forget about the weight difference about 40-50 Ibs plus I think the gearing is better for TPI equiped car.
Old Jul 27, 2005 | 05:40 PM
GOY's Avatar
GOY
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
From Cleveland Ohio - if you want a reasonable price for the setup, let me know, I'll drive to pick it up (half way would be great, but either way would work if what's the only way it would work.)
midge54
Sep 2, 2015 06:27 PM
Cacike
Aug 27, 2015 05:10 PM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
cRoe4
Aug 7, 2015 08:46 PM
