Squelling From Rearend
Old Jul 26, 2005 | 06:10 PM
klumb15's Avatar
i have a fully rebuilt 10 bolt, eaton limited slip unit and 3.73's....i'm not sure if this is normal or not, but i figured i'd find out before i hurt something...when i'm driving in a straight line, and turn slightly and kinda go back and forth, i can hear a slight squeel coming from the rearend, i hear it once in a while in town too....is this normal, or is this something I should be concerned about?
Old Jul 27, 2005 | 03:18 AM
Difflock's Avatar
Car: VIN=85 T/A, CAR=82/3 T/A gfx, go figure. She's a T/A anyway!
Engine: 5.0, Holley 600 cfm 4-barrel
Transmission: THM350 ??
Try gently applying the brakes whilst driving and see if the squeal goes away. It could just be the shoes/pads.
Mark.
Old Jul 27, 2005 | 04:12 AM
Rabbitt's Avatar
Car: 1987 Iroc-Z
Engine: 355
Transmission: 700r4 w/ about 7500 miles on rebuild
I have your exact setup (plus moser axles) and i get some gear whine myself..
Old Jul 27, 2005 | 02:48 PM
klumb15's Avatar
yea it only does it on slight turning, i'm thinking it might be that its borderline of engaging and disengaging....becase when i make a full turn, it won't make any noise, i think it just bumps in and out of posi when i slightly turn... i just wanted to make sure it was normal...it could be coming from exhaust too maybe, because i have duals dumped underneath and the mufflers are tucked up tight against the flowboards...so that might be squeaking a little...who knows...atleast its not a grind, that'd be bad..
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
86White_T/A305
Aug 17, 2015 12:16 AM
