kickdown cable problems
Old Jul 30, 2005 | 05:59 PM
z28maro's Avatar
Car: 1983 z28 camaro
Engine: 305 - LU5 bottom end.
Axle/Gears: 2.93 stock :-(
i have an 83 z28 with the 4-speed auto. my car went an engine fire years ago hence the deal i got on it. ive swapped it all out under the hood however the plastic end of my kickdown cable is still melted. is there an easy way to either change a kick down cable or put a new end on mine????
Old Jul 30, 2005 | 07:37 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Just change the cable.
Old Jul 30, 2005 | 10:14 PM
z28maro's Avatar
makes sense and that was the plan its just little bit of a pain and new cables are way over priced
Old Jul 30, 2005 | 10:50 PM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
a new cable is $30 www.7004r.com Make sure you get the correct one... they are actually different depending on what is goes on.. the carb one is the shortes, thaan tbi, then tpi is the longer on.. i found that ou on my 83. took a tranny from an 88 and put it in to find out the cable was to long (the 88 donor car was a tbi). and 30$ to get the right cable and have ot work right is a good investment since not having one means burning up the trans again a little later.
9192camaro
16
Feb 3, 2019 12:21 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
timonator
Aug 13, 2015 11:27 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
