Newer Shifter for an '82
Old Aug 1, 2005 | 11:14 PM
kboehringer's Avatar
Car: 1982 - Z28
Engine: 350 / CCC Q-Jet
Transmission: THM-700R4
Axle/Gears: 10 Bolt - 3.73
TGO Friends,
My son's shifter was modified by the previous owner to allow the use of a TH-700R4. The original '82 shifter does not have enough detents (NO Overdrive). The previous owner removed all the guts and replaced the ****. The tranny could be shifted without a key and without a button (very dangerous and very easy to go to Reverse straight from OD)
We purchased a shifter from a '90 RS. We had to modify the '82's tunnel mount and the mount on the shifter for the steering lock cable. We're having real trouble getting the adjustment correct for all gears. Also when we pull all the way to 1st the cable will not return properly (it's being pulled too far out.)
Is there a cable difference in the new models?
Is it stronger (i.e. lesss flex)?
Is there an aftermarket cable that's a bit stronger?
What gear do you guys set the Cable/shifter/Tranny at initially?
We looked a Jeg's but the cables they offer are only for aftermarket shifters... don't look like they'll work.
Any advice would be appreciated....
Sincerely
Kurt
Old Aug 4, 2005 | 11:46 PM
Car: 1982 - Z28
We figured it out.....
We found a cable and mount in a newer Firebird ('89?). It mounts closer to the Transmission lever (1 Bolt Closer) and the cable has more throw and is MUCH better constructed. TH700 works great now.
Old Aug 5, 2005 | 12:42 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Man, I guess when you change from 200c to 700r4 you need EVERYTHING! Looks factory, though, I'd say you did a real good job.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
ndndndnd
Sep 28, 2015 08:00 AM
