How do I make my own tranny cooler lines?
Old Aug 2, 2005 | 08:51 AM
TBI92Camaro's Avatar
Car: 92 Mustang Coupe/89 Camaro RS
Engine: 5.0 carb'd/305
Transmission: T5/T5
Axle/Gears: 3.73 and stock TrakLok/stock GM
Ok, I have some ghetto tranny lines with rubber hose and would rather have full metal lines. How do I go about this? What all do I need and where do I buy thel ine? what size do I need? Im running a TH350 w/2400 stall so tranny cooler is planned a bit later on but for now its not. Can I buy the fitting to screw into the tranny or will I have to use my old ones? I assume I need a flare tool and line and the ends off my old line correct??? any special bending tools? Need these done, going to be dropping the new combo in here pretty soon. Thanks.
Old Aug 2, 2005 | 10:23 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
You can make your own steel lines from scratch, your local parts stores should have the correct fittings. Bending steel lines is hard to do especially if you want to keep it looking nice. In my opinion you would be better off running braided lines or cutting off the stock steel lines and converting to braided.
I cut off the stock steel lines at the front of the motor and converted to braided line using compression fittings on my car. Heres a post with the part #'s.
https://www.thirdgen.org/techbb2/sho...s+cooler+lines
Old Aug 2, 2005 | 10:46 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
bending steel line is easy.
bending alum line is even easier.
bending stainless steel lines is harder.. but still not too hard.
your local autoparts store should have "brake line" or "fuel line" you can use.. you can also order the tubing in rolls.
if money is tight, you can rent a flare tool from autozone... they take a deposit, and when you return the tool, you get your money back.
for the bender, you want one with two handles, like this:
they're cheap and autozone, lowes, ect has them....
do NOT get the super cheap one like this:
any of the benders with one handle, that require you to press on the tube to bend it, generally wont be easy to use, and they usually dont do a good job.
once you have your lines and bender, start out by mocking your lines, either with a coathanger wire, cardboard or by eye... depending on what you feel comfortable with... then bend the line, check, bend, check ect... its not hard... but it is time consuming until you gain enough experiance that you can eyeball stuff and have it look right.
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
TreDeClaw
Aug 14, 2015 06:58 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
