VSS lead and connector
Old Aug 9, 2005 | 03:19 PM
88SC's Avatar
I'm putting the finishing touches on an engine swap, but wound up with an extra connector under the car. It's on the same branch as the backup light switch, the connector for which breaks out in the middle. The connector in question is at the end, fed by one yellow and one purple wire.
From the best I can tell it'd fit a VSS if I had one in the trans (T-5), except that my car has a cable In the heat of battle I managed to forget where it went.
Is it possible that in my year ('88) some F-bodies had a VSS in the trans and some didn't? If so, did they all perhaps get the same wire bundle?
If not, then does anyone know what and where the thing plugs into?
TIA,
Bob
Old Aug 13, 2005 | 02:33 PM
paulmoore's Avatar
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
My camaro was also a V6 and yes it too had a cable driven speedometer. I am going to be running an autometer electronic speedometer, and needed an electronic VSS to run it. This is a VSS from a V6 T5.
Old Aug 13, 2005 | 02:42 PM
paulmoore's Avatar
The connector on the VSS is a two wire connector, and the wires are purple and yellow as seen here.....
Old Aug 16, 2005 | 03:46 PM
88SC's Avatar
Thanks, Paul! That looks like the one.
One follow up question - what all was on the harness branch that went to your back-up light switch originally? Did it end at the back-up switch?
Thanks,
Bob
Old Aug 16, 2005 | 06:58 PM
paulmoore's Avatar
Well, I did alot of this modification a long long time ago. If memory serves, the only things on that 'branch' was the reverse light switch connector, at least for me. I had the V6 5 speed remember? But I guess if you had a newer model T5(89+) or an automatic transmission, you would have another connector there for the VSS.
$750 L98
Feb 1, 2025 02:25 PM
ZEEYAA
Apr 16, 2023 08:29 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
RS Reaper
Sep 27, 2015 07:04 PM
