Compression fittings on trans cooler lines?
Old Aug 14, 2005 | 09:45 AM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
I'm going to be mounting an aftermarket trans temp sensor soon, but first I just have a couple of quick questions:
1 - I will be connecting it to one of the trans cooler lines. Rather than use a manifold that costs 35 bucks, I have a bunch of brass fittings all screwed together. They go out to a 3/8 tee, because that's the size of the sending unit. Then back down to the 5/16 that's the size of the cooler lines. My question here is will compression fittings work to attatch to the lines, or do I NEED to flare the lines and use flare fittings?
2- Should I put it on the return line or the hot line?
Old May 23, 2007 | 05:49 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Re: Compression fittings on trans cooler lines?
What did you end up doing because I am having the very same issue?
Kevin
Old May 23, 2007 | 11:56 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I don't know how well a compression fitting is going to work on a steel line. It probably makes more sense to put the sender in the return line, so its measuring the temperature of the fluid as its used by the transmission.
Old May 24, 2007 | 07:20 AM
JohnZ28's Avatar
Car: 85 Z28
Engine: 383
Transmission: TH350
Axle/Gears: 3:73
I bought a remote filter for my TH350 which has an extra hole for mounting the sender unit instead of tapping directly into the lines or drilling a hole in the pan.
Old May 24, 2007 | 08:20 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Don't you mean the hot line? The return line's already cooled.
Old May 24, 2007 | 08:37 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Compression fittings suck !! When I had steel line and a tranny temp sensor In a tee exactly like you want to do they always leaked no matter what I did. I just got some Stainless steel flex hose and its worth every peeny I payed for it, you should look into it.
Old May 24, 2007 | 10:44 AM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
I have used compression fittings for trans lines, fuel lines, brake lines and steel and aluminum, I have even seen them on high pressure air and hydraulic tubing on heavy equipment and I have never in 25 years of using them had one leak or come apart. You have to make sure the cut is clean, with no deformation of pitting and the tubing is well seated inside the ferrule and fitting.
I do agree that the best method is using flared tubing of hoses.
Old Jun 12, 2007 | 09:08 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Summit stocks hard line adapters for the 5/16 tubing. I ran across this info from jbenge on this site and am using this information to hook-up my trans cooler. Part numbers are Earl`s. Part number 165056 is the tube adapter, 6an male to 5/16 tube. He also has some excellent pictures of the install, no leaks.
84z96L31vortec
Aug 20, 2017 12:16 AM
theshackle
Mar 5, 2017 06:37 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
armybyrd
Aug 10, 2015 09:23 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
