does anybody know if an SS 6 speed will fit in my 92 RS, please help
Car: 92 RS CAMARO
i've got a '92 rs origanally with a 305 but now i've put an older 350 in it and have gone with a carb.
my 700R4 went out and now i'm redoing the car and seriously want to put a newer SS's six speed in my camaro. i've never heard of anyone doing this before.
do any of you know anything about this procedure and if it will bolt right up or if certain mods need to be done to make it fit and work.
any info will be greatly appreciated.
a few q's to help me out with if anyone will are...
-will it bolt right up to the 350
-will it fit in the trany tunnel
-will i have to use the drivshaft from the 6 spd or rear end
-how much will i have to do to the console inside
thank you very much!!!
Re: does anybody know if an SS 6 speed will fit in my 92 RS, please help
'93-97 4th gen T56 will bolt in, just a regular T56 swap and it's been documented here.
'98+ 4th gen T56 will bolt in with an aftermarket (McLeod) bellhousing to accomodate the input shaft length difference, or swapping the input shaft and some other pieces...either way, it's the less-practical approach given the extra cost and effort.
Car: 92 RS CAMARO
THANKS BUT HAS ANYONE DONE THIS BEFORE OR HAVE ANY EXPERIENCE WITH THIS?
I GUESS I'LL SHOOT FOR A 97 THEN UNLESS ANYONE HAS A DIFF. APPROACH,
http://www.skulte.com/T56.html is a good starting place.
Also do a search on username MrDude_1 in just this forum and you'll get plenty of info, he documented his swap well and answers questions frequently.
(and fix your CAPS LOCK key)
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
that site is as a guide sort of some stuff you find out during the swap that isnt mentioned in any swap
its not that bad of a job
except when you get shipped the wrong flywheel
oops thats the only problem i occured obviously the clutch wouldnt bolt up oopspm me if you need any tips i got plenty of them for you
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
IBrockZ
Aug 20, 2015 12:20 PM
