third and fourth gear disapeared
Old Aug 16, 2005 | 01:22 AM
Captain Morgan's Avatar
Car: 89 Camaro Iroc-Z
Transmission: TH350
Axle/Gears: 3.42 7.625 10 bolt
I have recently just performed an automatic to standard tranny swap. I got it all back together started it on the stand and put it in reverse to make sure it worked and it did so i took it down, cleaned everything up and went for a test drive into town. Everything seem good all they way down my road and to the main road and i went through all the gears when turning onto the main road, i drove about 7 miles and when i got into town i attempted to downshift into 4th gear and there was nothing there, so i tried third, nothing there either..... the only gears i had were 1,2,5. So i drove over to a freinds house near by and checked the fluid and everything and it was full. I have no idea how the two gears could just stop working?????? ANY THOUGHTS OUR IDEAS would be greatly appreciated.. if it is something dumb i would like to fix it, if not i guess i will be buying a new tranny, suites me right for putting a used one in i guess
also any thoughts or comments on what tranny to put in? Built five speed or six speed swap possibly
Old Aug 16, 2005 | 01:25 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
the shift fork is either broken or bent, 1-2 has one 3-4 uses 1 and 5-r uses one
Old Aug 16, 2005 | 01:35 AM
Transmission: TH350
Im a little confused, what do you mean one and two has one and three and 4 have one and reverse and 5 have one. there is only one clutch fork. Also i dont know when it would have bent, it worked when i went through the gears to take off, and sometimes if you play with it a little it will go into gear, very very strange, no noise or anything, just cruising and when i went to down shift nothign was there. it feels like there is no synchro at all there what so ever
Old Aug 16, 2005 | 01:37 AM
Transmission: TH350
or by shift fork, do you mean teh shifter itself... ? man i feel dumb at this point... and its sad becuase im fairly decent with cars...
Old Aug 16, 2005 | 01:40 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
well theres a fork in the actual transmision, that the shifter slides into, they can break, and since there only 1 fork per 2 gears, its the logical thing at this point since 3-4 has its own fork
Old Aug 16, 2005 | 01:42 AM
Transmission: TH350
oh, guess that makes sense, i understand the basic concept of how the tranny works, but i didnt know that.... is that something that can be fixed relatively easy or cheaply or do i need a new tranny?
Old Aug 16, 2005 | 01:43 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
i think they are under 30 bucks for a new one, don't quote me though, and yes it can be done yourself no problem.
i'm not a tranny expert though
Old Aug 16, 2005 | 01:44 AM
Transmission: TH350
also, how come it bent while i was in 5th? becuase i didnt hear any noise or any rattle what so ever and it took off fine twice.... is there anythnig else it could be?
Old Aug 16, 2005 | 01:45 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
its possible that it just comes loose, i had a friend in a s-10 driving in 5th, went to downshift and there was nothing there, fork was all screwed up.
i'm not saying this is your problem forsure, but its a place to start looking
Old Aug 16, 2005 | 01:49 AM
Transmission: TH350
well thanks a bunch, i never even would have though or known of that, i put this tranny in and pulled it out twice already becuase i bought a defective clutch set, so im not sure if im gonna pay somebody or do it myself, but as you said its a place to start.
Old Aug 16, 2005 | 01:53 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
no problem, my advice is to get it taken in and checked out, transmissions are one place that doing a "good enough" job isn't usually gonna last.
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
88rscamar0
Sep 23, 2015 09:08 PM
Linson
Sep 21, 2015 01:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
