What's a World Class T-5?
Old Aug 23, 2005 | 06:20 PM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
How can I tell if my car has the world class or non-WC?
Old Aug 23, 2005 | 06:49 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
IIRC the WC T5 appeared in the 1990 model year. It was also a tad stronger.
Old Aug 24, 2005 | 03:41 PM
jimmy_mac's Avatar
It is a slightly beefed up version of the T5. I broke my T5 behind my stock lb9 305. I've had the WC T5 behind a 350 that runs 13.6 at 106 mph for 40,000 miles now. I don't use slicks obviously, and don't dump the clutch. But I do shift hard between the gears when making runs and it's still alive.
Old Aug 24, 2005 | 05:51 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
IIRC the year was 88. There's a bolt on the driver's side, a torx 50 (non-WC has a 21 mm 6 point).
JamesC
Old Aug 24, 2005 | 10:00 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
JamesC
Be sweet if it is 88, then I'd have two of them.
Old Aug 26, 2005 | 11:04 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
WC T5 debuted in the V8 3rd gen mid '88. WC rated to 350 lbs/ft. NWC rated to 250 lbs/ft.
WC uses fiber lined black synchro rings, NWC uses brass.
WC uses tapered roller bearings on teh countergear, NWC doesn't.
WC has needel roller bearings under the speed gears, NWC ride the gears hard on the shaft with no bearing or bushing.
Get the tag number from the tailshaft housing and run it through the decoder at 5speeds.com This will tell you year and application as well as WC or NWC. The number you need will be 1352XXX. The last three are the important digits.
Old Jul 30, 2006 | 12:46 PM
WhiteKnight's Avatar
Car: 88 GTA
Transmission: Manual
How could NWC T5s only be rated to 250 lbs/ft if 305s put out more torque than that?
Old Jul 30, 2006 | 08:16 PM
Basically it's stupidity. A 305, especially a TBI made 300+lbs/ft. But the trans was only rated to 250. Probably why they break often.
Old Mar 9, 2011 | 06:52 PM
larry88ttops's Avatar
Car: 1988 Camaro w/T Tops
Engine: 305 TBI
Transmission: Borg-Warner 5 spd
Re: What's a World Class T-5?
Thanks - building my library
PurelyPMD
May 5, 2016 04:57 PM
gt4373
Oct 8, 2015 10:37 AM
Damon
Sep 26, 2015 04:29 PM
scottmoyer
Sep 7, 2015 07:06 PM
jtwoods4
Sep 3, 2015 05:39 PM
