86 firebird V6 T5 into 85 berli auto?
Old Aug 24, 2005 | 05:17 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
My friend has a 1985 Camaro Berlinetta, with a 2.8 and the 700R4. We picked up a parts car, a 1986 Firebird with a 2.8 and a 5 speed.
Is this a straightforward swap? Due to the massive amount of electronics on the Berli, will this be an issue?
We will get a new pressure plate, throwout bearing, and disk... as well as have the flywheel resurfaced.
Is the auto to stick conversion hard? Are all the holes and such already there?
Any input would be great! Thanks!
Old Aug 25, 2005 | 06:44 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
especially the speed sensor. how does the berli sensor work?
Old Aug 25, 2005 | 04:59 PM
Toehead's Avatar
Nobody has any idea whether or not the berli uses the same vss as the regular t-5?
Old Aug 26, 2005 | 11:15 PM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
pre 89 camaro's had cable driven speedo's, 86 and up firebirds had electronic speedo's. you will need either a guage setup from an 89+ camaro or 86+ firebird, or a t-5 vss from an 82-85 firebird or 82-88 camaro. a 700r4 vss will not work, it is a different size.
Old Aug 27, 2005 | 08:40 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Wait, I'm a little confused by your post. First, we can't change the cluster, as it has the special digital dash. Second, except for the Berlinetta, I didn't think the Camaro got the VSS till 1989?
rubblerubble
Mar 13, 2016 06:57 PM
okfoz
Oct 13, 2015 02:19 PM
Linson
Oct 1, 2015 09:50 PM
BlackphantomZ28
Aug 31, 2015 11:19 AM
theshackle
Aug 23, 2015 03:49 PM
