T-5 hold up to a built 350?
Old Aug 24, 2005 | 06:28 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I'm swapping an engine and transmission into my T/A right now and I have a few options. I was wondering if I should get a T5 or wait and get a WC T5. I'm hoping to get about 300hp+, basically I'd like a 350 and get exhaust, new intake, cam, porting, heads, etc. Will a T5 or WCT5 handle alot of power like that?
Old Aug 24, 2005 | 06:31 PM
Red|ine's Avatar
Car: '83 Z28
Axle/Gears: 3:73
No.
heh... no. go with a WC at least, or look into a t-56!
Old Aug 24, 2005 | 06:49 PM
Car: 86 T/A
Engine: HSR 355
Thanks, that's what I thought but I wanted to double check. 6speed is tempting...
Old Aug 24, 2005 | 07:48 PM
Red|ine's Avatar
Car: '83 Z28
Axle/Gears: 3:73
yeah, i cant wait to shift into 6'th the very first time, it'll be like seeex.
Old Aug 24, 2005 | 07:55 PM
jimmy_mac's Avatar
The wc t5 will last if you treat it right. I have one behind a decently powered 350 for a while now. But if I had the resources at the time I'd of gone with the T56.
Old Aug 26, 2005 | 10:55 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
A stock WC T5 is good to 300 lbs/ft per Tremec (formerly Borg/Warner). You can strengthen a T5 to take up to 500 lbs/ft. with G-Force parts. Another step up is a Superalloy conversion. Cheaper than the G-Force setup and up to the task of 400 lbs/ft. PM me if you are interested. I do these in house.
camaro11j
Sep 19, 2018 08:49 AM
Eric-86sc
Aug 24, 2015 09:01 PM
neekolzun
Aug 24, 2015 04:59 PM
NWAsonoma
Aug 18, 2015 05:45 PM
