Trans Gears... What does it all mean...
Old Aug 26, 2005 | 11:38 AM
JerseyMark's Avatar
Car: 1991 RS Convertible
Engine: 96 LT1
Axle/Gears: 3.45 9-Bolt
Hey everyone,
I am almost done with my T5 swap. I did some digging in the Tech Database and found out what my old gears were and what my new gear are. The trans that I got is a World Class T5 from a V6. Below are the gear ratios. Please help me understand what changes this will make to my performance. 1st gear is drasticly smaller, so I am sure that will help my off-the-line performance(If I can get traction) And the highest gears in the two trans are close to eachother so my highway RPM's will be about the same. But how about everything inbetween? And what will be the overall difference?
Trans ----- 700R4----- T5
1st ------- 3.06------ 4.03
2nd ------ 1.63 ----- 2.37
3rd ------ 1.00 ------ 1.50
4th ------- 0.7 ------ 1.00
5th ------------------ .76
Thanks in Advance,
Mark B
Old Aug 26, 2005 | 11:41 AM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
Umm i thought the v6 5spds wouldent mate with the v8, did you modify it somehow?
Old Aug 26, 2005 | 11:45 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
if the t-5 came from a 4.3 liter it will.
Old Aug 26, 2005 | 12:00 PM
JerseyMark's Avatar
Engine: 96 LT1
The trans came from a 91 V6 Camaro. The it has a custom 10.5" clutch to make it work with the V8. Below is a quick chart I made from the calcualtors on this great website. Let me know what you think.
Old Aug 26, 2005 | 08:50 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Isn't the bellhousing bolt pattern different for the 2.8 and 3.4l v-6s than the v8'?
Old Aug 26, 2005 | 10:18 PM
87zjeff's Avatar
a 4.3 liter bell has the same pattern as a v-8. the 2.8 and other v-6's are different.
Old Aug 26, 2005 | 10:35 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Yes but he said that he got the tranny from a 91 camaro. They didn't come with 4.3l (3/4 350's).
Old Aug 26, 2005 | 10:58 PM
87zjeff's Avatar
the bell housings are removable so it would just be a matter of changing the bell housing.
Old Aug 26, 2005 | 11:36 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
NM i'm retarted, and a special clutch to make the v8.
But i hear the v6 trannys are quite a bit weaker than the v8's so...
Old Aug 27, 2005 | 12:49 AM
87zjeff's Avatar
that part i don't know much about. i haven't dealt with many manual shift transmissions.
Old Aug 28, 2005 | 11:47 AM
JerseyMark's Avatar
Engine: 96 LT1
They arent weaker. As long as its a world class, its just as strong as the V8 world class. The advantage is that the transmission has only seen V6 power all its life. So there is less wear. The only thing that may make it break faster is that the gear ratios are lower. So that will put more strain on the trans when I am racing. But that is the risk I take for getting better gears.
1992 Trans Am
May 10, 2023 07:19 PM
Hawk312
Aug 22, 2017 08:55 PM
Hello, Michael
Aug 20, 2015 03:19 PM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
