shifting problem question
Old Aug 29, 2005 | 12:32 AM
thirdgenrs's Avatar
Car: 90 RS Camaro
Engine: 383L98
Transmission: t-56
Axle/Gears: 10bolt 3.42/posi
my car will not shift out of first gear at wot. this is a 700r4 with a couple thousand miles on it, new valve body, transgo shift kit. my question is could it by my rebuilt 2600 stall that is the problem? if its f'd up would it keep my tranny from shifting?
Old Aug 29, 2005 | 04:53 PM
Z28cross-fire's Avatar
Car: '94 Z28
Engine: LT1 350
Transmission: 4L60E/A4
Does it shift out of first when driving normally? If it does then somethings slipping.
Old Aug 29, 2005 | 08:40 PM
thirdgenrs's Avatar
Car: 90 RS Camaro
Engine: 383L98
Transmission: t-56
usually normal driving it will shift fine out of first and no slipping. its only at wot that it will not shift.
Old Aug 29, 2005 | 10:05 PM
91ChevyRS's Avatar
Car: 1998 Volvo S70
Engine: B5254S Engine
Transmission: Automatic
Axle/Gears: It's a volvo?
ok I have one question and one question only.....
WHAT THE HELL DOES WOT stand for?!?!?!?!?!
BLEhghajsa
Old Aug 29, 2005 | 10:47 PM
thirdgenrs's Avatar
Car: 90 RS Camaro
Engine: 383L98
Transmission: t-56
wot= wide open throttle
Old Aug 29, 2005 | 11:29 PM
greggbruce's Avatar
Car: 84 454 monte, 89 formula, 86 camaro
Engine: the bigger the better
Transmission: 700/4L60 in everything
Axle/Gears: wish they were all 4.10's or better
Re: shifting problem question
no, the converter won't do that---there's something wrong with the TV valve or the shift valve or the seperator plate. (or maybe the governor, but probably not)
get with whoever put the valve body on it and find the right one WITH THE RIGHT SEPERATOR PLATE, there are 3 different setups and about 6 different plates, it is important to get the right ones.
what was wrong with your old valve body?
I would suggest you use it and the plate that went with it, put the shift kit in it.
or do what I do, drill the plate like in the B&M shift kit, eliminate the travel in both accumulators (remove springs, install spacers) and let it fly. works awesome.
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
dhonda200
Aug 11, 2015 11:50 PM
