What gear do i have?
Old Sep 2, 2005 | 07:43 PM
sam's Avatar
sam
I can drive my 88 Aut. 305 TPI firebird 80mph at 2000 RPM in 4th
Anyone know by this if the gears have been changed? Tires are stock dimensions
thanks,
Sam
Old Sep 2, 2005 | 11:43 PM
88TATBI5.7's Avatar
Car: 88 TA
Engine: TBI 5.7
sounds like 2.73 but the only way to tell for sure is to pull the cover and count the teeth. ring divided by pinion = ratio
i have 2.73 and i turn around 2000 rpm at 80 and 1700 at 70.
tire size is 225/60r15. or is 235/60r15. bought tires cant remember but they a damn close
Old Sep 3, 2005 | 12:52 AM
Z28cross-fire's Avatar
Car: '94 Z28
Engine: LT1 350
Transmission: 4L60E/A4
Please do a search next time, this topic is brought up so often. But anywho, here are the RPO codes so you can check if you don't want to take the cover off.
GU2 - 2.73
GU4 - 3.08
GU5 - 3.23
GU6 - 3.42
GW6 - 3.27
GM3 - 3.45
GT4 - 3.73
G80 - posi
G92 - performance
Old Sep 3, 2005 | 03:21 PM
sam's Avatar
sam
Thanks forn the replies. Is the code on the rear end?
I have the w6 packet.... maybe i have GW6 - 3.27 ?
Sam
Old Sep 3, 2005 | 03:36 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Sam
Don't bet on it, just check your RPO codes.
Old Sep 3, 2005 | 05:42 PM
Car: '94 Z28
Engine: LT1 350
No, it's a sticker with a bunch of three letter digits, usually in the glove compartment or center console box. Just look for three letters/numbers with one of them combonations.
And if you're spinning 80 mph with 2000 RPM, there is no way you have 3.23, you have 2.73's forsure. Heck, i spin 1800 going 65-70 mph and i have 2.73's
Old Sep 3, 2005 | 09:32 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
i have 3.27's and i turn 2000rpm at 60 mph
Old Sep 6, 2005 | 01:44 AM
sam's Avatar
sam
thanks everyone,
Help appreciated, turns out i have the 2.73
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
