T-5 Questions.
Old Sep 7, 2005 | 03:51 PM
jumpinjoe's Avatar
Car: 1989 IROC-Z 1LE/ 89 IROC-Z T-Top
Engine: 305TPI/uh..also305TPI
Transmission: 5SPEED/auto
T-5 Questions.
Hey i was also wondering if you can change a V-8 T-5 with a V-6 T-5? I work for a used car dealer and my mechanic here thinks they will interchange but i thought i should ask all you third gen gods out there. i'm skeptical because i can get V-6 T-5's for 125.00 all day but i keep getting told that the V-8 T-5's are 8-900.00. if someone can help me here i would appreciate it.
Old Sep 7, 2005 | 07:00 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Nope, the input shafts are different.
Old Sep 7, 2005 | 07:41 PM
jumpinjoe's Avatar
thanks i appreciate it.
Old Sep 8, 2005 | 09:54 AM
jumpinjoe's Avatar
Old Sep 10, 2005 | 10:04 AM
jumpinjoe's Avatar
what if i use a 6 cylinder clutch?
Old Sep 12, 2005 | 07:34 PM
Jrod26's Avatar
Car: 1991
Transmission: 5-Speed Manual
I am wondering the same thing. I heard that you could change the clutch and it would work but what I was wondering can you change the input shaft??? And would using a clutch for a 6 cylinder affect the perfomance of the clutch????
Old Sep 12, 2005 | 10:19 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
If your looking for a tranny for your car, be careful as yours is quite a bit different than a typical V6. Your car will have the world class borg warner with the 5 gear overdrive ratio of 0.74. It is quite common to find the 5 speed's with the 0.63 overdrive.
Mark.
Old Sep 14, 2005 | 11:16 AM
z28crazy's Avatar
Car: 86 Z-28
Engine: 356 4-bolt
Transmission: Borg warner T-5
the v-6 t-5 will work with a different clutch. actually i think just a different friction plate. the v-6 t-5s come with a 14 spline input where as the v-8s come with 26 splines. if your willing to hunt down a clutch that is 10.5 inch and 14 spline it WILL work!
Old Sep 14, 2005 | 11:47 AM
jumpinjoe's Avatar
Yeah that what my mechanic said. In my area we have a place called, proven force, where we get all our clutch kits and tranny parts. they have a great centerforce clutch kit for 265.00 for the
V-6. i'm just worried about the torque rating of the 6cly trans. at this point im ready to just throw in a T56 and be done with it! I want to keep it close to original as possible, so i'll get the original rebuilt and keep it for if i sell the car.
Old Sep 15, 2005 | 12:44 PM
z28crazy's Avatar
Car: 86 Z-28
Engine: 356 4-bolt
the torque and HP are the same; however, being a 14 spline and not a 26 spline it is said that the input will be prone to slipping and stripping. But the way i look at it is that you would have to be running a BB to get enough power to do that...a v-6 trans will do just fine!
Old Sep 15, 2005 | 02:26 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
Go to the drag forum... There's a guy running low 11's with a v6 T-5 in his car.
I know it makes you but its true.
to that guy
Old Sep 15, 2005 | 03:43 PM
jumpinjoe's Avatar
a V-8 car with a V-6 trans, or a V-6 car with a V-6 trans?
meeklay812
Oct 1, 2015 03:46 PM
Royal_Z
Sep 30, 2015 08:45 PM
raymondandretti
Sep 27, 2015 06:43 PM
luvofjah
Sep 26, 2015 08:28 PM
DARKmj16
Sep 9, 2015 04:07 PM
