bad vibrations
Old Sep 8, 2005 | 01:01 PM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
bad vibrations
i have been having a vibration issue ever since i bought my car. the car seems to vibrate at high speeds no speedometer but i would say 60 70 mph.
now since i bought the car the motor has been changed all rear suspension has been changed except torque arm and driveshaft.
but i did swap in another stock driveshaft if that matters. new rear end went in,driveshaft loop went in, poly trans mount, new front ball joints,lower control arms. tires and rims and got an alighnment.
note it has ben vibrating even before i changed everything so i know it's nothing i put in.
and besides the whole car vibrating i can feel it through my shifter and it seems to vibrate more when i let my foot off the gas for a bit.
any ideas?????????????????
Old Sep 9, 2005 | 08:15 AM
Difflock's Avatar
Car: VIN=85 T/A, CAR=82/3 T/A gfx, go figure. She's a T/A anyway!
Engine: 5.0, Holley 600 cfm 4-barrel
Transmission: THM350 ??
Undo the driveshaft from the rear axle. Spin it half a turn and bolt it back in, see if that helps, or makes the vibration worse.
Mark.
Old Sep 9, 2005 | 12:34 PM
Bobbyz's Avatar
Engine: 350 "ZZ4"
yeah i will give that try at this point i will try anythning lol
i wish i can explain it better if im cruiseing i can start to hear it sort of like a wa wa wa wa wa wa and lets say i give it more gas to pass it will get faster. so it's obviously something spinning.
Old Sep 13, 2005 | 02:11 PM
HorseflyDF's Avatar
Car: 86 Camaro Z28
Engine: 350 sbc goodwrench
Transmission: T-5 in the works
Axle/Gears: 10 bolt 3.42 open
Bad VIBES
Sharing some info on bad vibes
I have the same vibrations up threw the shifter also.
Its shaking the driveshaft at the ujoints.
Turns out its coming from the rear end.
I have posted on this board about my progress, which
at this point I have narrowed down to either axle bearings,
bent rim, or spider gears.. the rear end is about only
main component that hasnt been change or rebuilt.
A friend from work was following me one day and told me
my right tire which is the power one legger had a wobble.
2.73 open.
Since then I havent driven the car but have taken both axles
out and switched them to see if its a bent axle. Not a bent axle.
Possibly
Bent Rim?
spider gear with the splines I think they ride on bearings?
Not sure if thats called case bearing?
Old Sep 13, 2005 | 02:35 PM
Bobbyz's Avatar
Engine: 350 "ZZ4"
i've had the vibration when i first bought the car changed a bunch of stuff including the rear and no change. but anything is possible
Old Sep 13, 2005 | 06:49 PM
HorseflyDF's Avatar
Car: 86 Camaro Z28
Same thing here when got the car it had that knock on and off
around the shifter.
The previous owner said it was the speedo cable
that was broken. There wasnt even a drive gear on
the tailshaft..
I just thought it would be a cool car to mess around with,
gonna put antique insurance on it in a few months.
Hopefully before it gets cold ill be able to fix the rear end
or get another used one...
69GTOby
Apr 18, 2016 02:34 PM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
sac92transam
Oct 7, 2015 02:31 PM
InfinityShade
Sep 18, 2015 08:32 PM
gta892000
Sep 16, 2015 12:40 AM
