Speedocable
Old Sep 13, 2005 | 04:43 PM
ThUnDeR2005's Avatar
Car: 1990 Camaro "RS"
Engine: 355 TPI
Axle/Gears: 3.23 LSD
Speedocable
does anyone know if theres a difference in speedocable between a 700R4 and a T5?
Also... if there isn't, will that particular speedo cable work with a th350?
Reason I ask is because in my swap, I also changed from T5 to TH350. I went to put my speedo in today and well for some reason I couldn't. Maybe it was the gear on the cable that didn't fit?
Any help would be appreciated.
Old Sep 14, 2005 | 01:20 PM
Engine: 355 TPI
bump
I went to take a look at my T5 and noticed it had the threading so you could thread the collar of the speedometer cable into it. My th350 doesnt have it. This is where I'm running into a problem.
Old Sep 14, 2005 | 01:42 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The threaded sleeve should pull out of the T5 (after removing the single bolt and retainer). Whether it will slip into the TH350, I don't know.
JamesC
Old Sep 14, 2005 | 01:43 PM
Engine: 355 TPI
Ok, thanks thats a start! I'll get on it asap
Old Sep 15, 2005 | 03:32 AM
Engine: 355 TPI
Well for an update..
it slips in. I think the retainer fits in the right spot.. its hard to tell, this damn B&M bracket for my torque arm is in the damn way! Its so hard to put everything in place. My left hand was getting too shaky from not eating all day and I kept dropping the bolt on my head LOL. Really annoying.
I'll give it a shot in the morning. Heh
Old Sep 15, 2005 | 07:25 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
A TH350 can have either small (like T5) speedo gears or large (BOP TH350, 700-R4 sized driven gears. In some cases, T5 parts are all you need. There are also two different sleeves on the larger driven gears / sleeves; one for higher tooth count; another for lower.
Sounds like you're on the right track.
KnightmareCS
Apr 15, 2011 08:10 PM
i_love_thirdgen
Sep 22, 2007 12:25 AM
