Poly Transmission Mount Problem
Old Sep 18, 2005 | 10:52 PM
TJfive0's Avatar
Car: 2008 Toyota Rav 4
Engine: V6
I just bought a poly transmission mount from a guy on third gen. It was on his TH350 and he said it should fit my T-5. I think it should, but for some reason it doesn't line up right. It looks like the holes are in the same spots as my stock mount, but when I get it all one, the last bolt that bolts the cross member to the tranny mount doesn't line up. It just won't no matter what. Is there any reason for this? Any suggestions what to do?
Thanks guys!!!
Tony
Old Sep 19, 2005 | 12:07 AM
morpwral's Avatar
Car: 82 Firebird SE
Engine: 350 CCC 4bbl
Axle/Gears: 10 Bolt, 3.23
It's possible that you installed it backwards. I believe it is suppose to be installed with the rounded side towards the rear of the car. I have one on my '82 (4 spd to 5 spd conversion, same mount) and a '95 T/A M6. They are both set up the same. I think it helps to bolt the crossmember to the mount first then the x-member to frame. That's how I did it and was not much of a problem. Helps to have the instructions but I do see that you bought it used so they were probably not available. All holes are slotted to allow some adjustability. Also some people had to enlarge the slot where the trans mount bolts to the x-member to allow for the provided SAE bolt. Hope it helps, good luck.
Allan
Old Sep 19, 2005 | 12:15 AM
TJfive0's Avatar
Engine: V6
Would it be better to enlarge the slot where the mount bolts to the tranny or enlarge the slot on the x memeber? Mine isn't lining up left to right. It is about 1/8 of an in off. I was thinking if I enlarged the slots on the mount itself, it should slide enough over to fit well. Does that sound right? And would that harm the mount in anyway?
Old Sep 19, 2005 | 02:03 PM
TJfive0's Avatar
Engine: V6
Anybody any ideas?
Old Sep 20, 2005 | 12:06 PM
TJfive0's Avatar
Engine: V6
I was thinking, could it be possible that the reason it is off 1/8 left to right is because when I took the cross member off, the tranny slid a little left to right while on the jack. I mean I have it jacked up slightly to support it. But I did notice it slightly shifted when i got it all off completely. Could this be the reason it appears it doesnt fit?
Old Sep 20, 2005 | 04:20 PM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Axle/Gears: 9" ford 35 spline axles
is it just not lining up where it bolts to the crossmember? Have you tried to pry over the trans to get it aligned? if you had it loose it probably moved....
Old Sep 20, 2005 | 08:32 PM
TJfive0's Avatar
Engine: V6
Yeah, I am going to try that on thursday when i get home. I think the tranny might have shifted a bit. Thanks
Old Sep 24, 2005 | 10:33 PM
TJfive0's Avatar
Engine: V6
Problem solved, runs as smooth as ever!!!!!!!!
Old Sep 26, 2005 | 12:18 AM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Had the same problem, all it was, a little persuasion with a crow bar, and the tranny moved right into position. Am glad everything worked out for ya.
Old Sep 26, 2005 | 07:19 AM
TJfive0's Avatar
Engine: V6
xlwhellraiser, I love your avitar, that is so sweet!!!!!! I want it
Old Sep 26, 2005 | 01:33 PM
One of the members on this forum, maybe two already had them, so it free domain by any means. I am sure you can use it without a problem.
jhawkeye
May 25, 2022 06:33 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
NBrehm
Aug 5, 2015 07:57 PM
