T5 problem
Old Sep 26, 2005 | 10:39 PM
4banger82's Avatar
Car: 84 camaro F41
T5 problem
i just installed a t5 for my 4 cyl 82 camaro. the clutch doesnt disengage when the clutch is pressed in. i think it might have somthing to do with the pressure plate being shaped differently, but i dont know how to fix it. any tips or ideas would be greatly appreciated.
Old Sep 30, 2005 | 10:16 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
Did you have the fly wheel turned .Is this a new clutch kit matching disc and plate . The p-plate should be the same aslong as it is for your aplaction evan if it looks diferante. Is the clutch fork moving freely did you mess with the hydrolic clutch line ?.
Old Oct 1, 2005 | 04:11 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
No, he doesn't have a hydraulic clutch.
Adjust your clutch linkage rod. You'll need to extend the rod that goes between the clutch fork and Z-bar.
If that doesn't work, you may have put the throwout bearing in the clutch fork the wrong way.....seen that happen before.
Old Oct 1, 2005 | 04:41 AM
4banger82's Avatar
Car: 84 camaro F41
alright... i think it has to do with instalation. ive tried extending the rod almost 2 inches, and it feels like there is alot of pressure on teh pedal, but it still wont disengage... i might just have to reinstal it.
Old Oct 1, 2005 | 05:15 AM
Confuzed1's Avatar
Car: 83Z28 HO
This may or may not help:
https://www.thirdgen.org/techbb2/sho...rowout+bearing
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
