G92 axle
Car: 1995 Firebird Formula
Transmission: Th350/4k stall
Axle/Gears: 10 bolt with 3.42s
G92 axle
just wondering i have a 91 z28 and have a rpo code for G92 axle does anyone know what gear ratio this is. thanks
Car: `86 SS / `87 SS
G92 is not a specific ratio. It does not, and has never referred to a specific numeric ratio.
G92 is an optional final drive rear axle ratio. I.E. if 2 ratios were available, the numerically higher ratio (3.73 rather than 3.23) would carry that RPO.
Now look through your other G _ _ codes and look up the one for the rear gear ratio.
there is another RPO it is G80. if this helps at 60mph its running about 2250 RPM
the other code is GU5
