hurtin 700
Old Oct 3, 2005 | 10:51 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
hurtin 700
when my car is cold works fine goes right into drive after it gets good and warmed uped and i pull it back into drive it feels and sounds like it is kicking in and out of gear doesn't do it in reverse just in drive at a stop if im moving and slip it into neutral and pull it back its fine could it be the torque converter?
Old Oct 7, 2005 | 09:14 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Old Oct 8, 2005 | 09:08 AM
Vader's Avatar
Sounds like you might be losing line pressure once the oil warms up. That could be due to many things, from the pump to seals, pressure regulator, accumulators, etc.
Old Oct 8, 2005 | 09:31 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Rebuild time.
86IROC112
Nov 27, 2015 09:54 AM
armybyrd
Oct 24, 2015 06:59 AM
84 TA NV
Sep 6, 2015 08:02 PM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
Third_Gens_Rule
Sep 3, 2015 06:55 PM
