trans re-d0
Old Oct 10, 2005 | 11:28 PM
4banger82's Avatar
Car: 84 camaro F41
trans re-d0
alright, about three weeks ago i swaped the stock 4 speed out and tried to put in a t-5 into my 4 cyl 82. the clutch doesnt disengage so its always in gear. other than that, eveyrything is fine. are there any words of advice or things i might look for when im pulling out the drivetrain and trying to redo the insalation?
thanks
Old Oct 11, 2005 | 12:28 AM
CrazyHawaiian's Avatar
Car: too many ...
Sounds like the throw out bearing. I've been told its a wear part so it should be replaced when the clutch is replaced. Maybe just try a new one.
Old Oct 11, 2005 | 12:30 AM
4banger82's Avatar
Car: 84 camaro F41
i got a brand new clutch kit from some other vehicle with a 9" clutch but with 26 splines, so the it has a new pressure plate, throwout bearing, and clutch. the pressure plates are shaped differently, do you think that might be it?
thanks
Old Oct 11, 2005 | 12:36 AM
Car: too many ...
It might be, I cant say for sure, I've never run a 9" clutch. I would try a search to see who else tried the S10 clutches (I know others have done it) and see what parts they had to use or what happened with the install.
1992 Trans Am
May 10, 2023 07:19 PM
Hawk312
Aug 22, 2017 08:55 PM
Hello, Michael
Aug 20, 2015 03:19 PM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
