Driveshaft removal question
Old Oct 13, 2005 | 01:38 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
Just a quick question about removing the driveshaft from the pinion flange.
Instructions in the chilton manual say to mark the relationship of the end of the drive shaft to the pinion flange. I dont understand why you need to do this......its seems like there is only one way that the driveshaft can fit in the flange (or 2 ways if you count turning it 180 degrees).
Right? I mean the shaft yoke and the pinion flange (because of the shape of the U-joint) should always fit at 90 degrees to eachother.
I just dont want to create more bullsh-t for myself when reassembling.
Old Oct 13, 2005 | 01:46 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
If you install it 180 out there is a posibiltiy of balance issues. Due yourself a favor and mark it.
Old Oct 13, 2005 | 04:57 PM
OK....gotcha. Thanks.
Frozer!!!
Jan 19, 2024 04:55 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
