4.10's and a T5 = lousy gas milage
Old Oct 14, 2005 | 10:11 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Anyone else running a WCT5 with 4.10 gears?
Is your mileage on the highway terrible?
City driving is fine since I can keep the RPMs below 2500 easily, but on the highway I am anywhere from 2500-3500 while cruising. Not sure how fast I am really going since the car has a 3.45 sender in it but I am usually hoverering between 80-100 on the speedo.
Old Oct 14, 2005 | 12:27 PM
TPI Monte SS's Avatar
Car: 1988 Monte SS
Engine: ZZ4-cammed TPI 355
Transmission: World-Class T5
How bad is it? I get near 21 mpg with my T5 and 3.73s, usually crusing between 65-75.
Old Oct 14, 2005 | 07:41 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Man, 21mpg highway, I get about 10-12 avg. with LB9/T5 with only 3.42's
Old Oct 14, 2005 | 08:22 PM
Car: 1988 Monte SS
Ouch! Even when beating the snot out of my car I average about 12-14 mpg. Time for new O2 sensor and tuneup maybe?
Old Oct 14, 2005 | 08:39 PM
Dialed_In's Avatar
No, its running great. Maybe I ought to re-calculate my mileage.
Old Oct 14, 2005 | 09:20 PM
hot92z's Avatar
Car: 92 Camaro Z28
Engine: LB9
Transmission: world class T5
Axle/Gears: stock ten bolt
damn you guys wont believe me.....
15 city
25+ highway on 3.27s<======I tend to stay at 60-65 since iam never in a hurry
Old Oct 15, 2005 | 05:01 AM
Zepher's Avatar
I think it's in the single digits.
I did get pretty decent mileage with the 3.73's, about the same as you on the highway if I just cruise.
Old Oct 16, 2005 | 10:01 AM
rjmcgee's Avatar
I don't actually figure mine, but I can get around 150 miles out of a tank. With a .63 overdrive it seems about right out on the highway. When I ditched the Edelbrock for the Demon carb the milelage suffered pretty bad.
A couple years ago when I was going through several differant rear ends I had a set of 2.73's which was a horrible pain in the *** with the 5 spd. Took it to the coast once and got over 20 mpg out of it.
Old Oct 16, 2005 | 11:02 AM
jimmy_mac's Avatar
Re: 4.10's and a T5 = lousy gas milage
So how are you calculating the mileage then? Doesn't the odometer run off the spedo cable also? I could be wrong about that, I just always assumed the odometer turned in relation to the speedometer gear in the dash. If that is true then it's off also.
Old Oct 16, 2005 | 10:24 PM
Zepher's Avatar
Re: Re: 4.10's and a T5 = lousy gas milage
Well, I know how far approx I am driving to and from where I go and I know how much money I am putting in the tank as well as the trip odo saying that I got 60 miles for $15, which I know I didn't travel 60 miles since the speedo is way off.
Old Oct 17, 2005 | 08:03 AM
blackgold84's Avatar
Car: 1984 Z/28 Camaro
Engine: 350ci
Axle/Gears: 9" 3.73 spool
like your 4.10's
hey guys,
do those of you using 4.10 like them, perfomance wise when combined with the t-5?
i have a non-wc t-5 and i am gonna do gears and a posi upgrade from my 3.23 open diff, and cant decide if 3.73s or 4.10s should go in.
i really wont do much highway driving, but i do like to race on the highway, does 4.10 mean no more 120-130mph blasts?
@ 70mph what rpm do you guy sit at?
-doug
Old Oct 17, 2005 | 11:13 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Doug - with my Ford 9" 4.11's and WC T-5 I'm running about 2500-2600 RPM at 70 MPH. ANd that is the correct speed, it's been verified while setting up my Dakota Digital VSS conversion box.
4.11 gives great "hole shots", but if you're after top end 120-130 blasts then you're probably better off with 3.23 or at most 3.42's.....
Old Oct 17, 2005 | 12:10 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I got an honest 25 Mpg in my Formula going down To Dayton OH, from Flint, (about 260 miles) one tank of gas, and I have Richmond 3.73's On the way back I got 21 Mpg, but I think that had to do with when I filled my tank just befroe coming home my filler neck was low and I did not get a true full tank.
But I have an Automatic a .040 over 305, and I changed out the speedo gears.
If you have not done so, with your 305 TPI setup, I would invest in some time programming your computer... Mine was running waay rich, and it really helped just to level out my BLM's
John
Old Oct 17, 2005 | 01:44 PM
Zepher's Avatar
I'll start playing with the program soon, just haven't had any motivation to tune.
With 3.73's I was still able to peg the speedo, but I think the speedo was showing 10mph higher, so I was probably doing close to 130mph.
4.10's pull very hard with the T5, which I like a lot, I just end up shifting so much.
At the auto-x yesterday, the 4.10's worked great, kept it in 2nd and even slowing down and then accelerating in 2nd, the 4.10s helped accelerate me quickly.
Old Oct 17, 2005 | 04:43 PM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
your formy looks like it tripped is its going to fall over in your sig
is your suspension still good? i never have the pleasure of seeing mine from the outside when im doing that :P
i always have trouble beliving 25mpg on 3.73's, could someone get me 35mpg on my 2.73's?? id appreciate it
Old Oct 17, 2005 | 04:44 PM
Zepher's Avatar
suspension is new, and nice and stiff.
I am in the process of going through the slolom very hard.
Old Oct 17, 2005 | 04:50 PM
dr1's Avatar
dr1
Engine: 305 TBI
ahh, yeah come to think of it I guess that doesnt look bad at all, heh
that car looks good in action
Old Oct 17, 2005 | 05:01 PM
Zepher's Avatar
here is a video from July at the same place,
http://www.transamws6.com/video/manny-acu4.wmv
Looks better in motion, imo.
Old Oct 18, 2005 | 06:58 AM
okfoz's Avatar
Zepher,
Did you "upgrade" your suspension with aftermarket, or did you stay with the stock sway bars. I have seen the aftermarket stuff, and it seems smaller in diameter than the OEM WS6 stuff.
I was just wondering.... I know my car with the stock springs and sway bars with the KYB shocks, Boxed in control arms and pan hard bar it rides like a Vette, but it handles great. At 120 it is glued to the ground.
Just wondering what all you did
oh, BTW, your name is now a car nameplate. Lincoln is coming out with a new Zepher... Actually its a revitalization of an old name.
John
Old Oct 18, 2005 | 10:27 AM
Zepher's Avatar
John,
I've got the stock sway bars on the car.
The upgrades consist of Eibach Sportlines (which I've read handle just like the stock WS6 springs but give you a lower ride height), KYB GR-2 front struts and KYB Gas-a-just rear shocks, BMR panhard, and Lakewood LCA's with poly on the body and rubber on the rear since I've read that poly/poly can bind when cornering hard.
My car also handles great at speed, I've done a few 120-140 8 mile runs on the HOV lanes they have here, it has mild corners and elevation changes and the car sticks to the road like it's on rails. I won't do that on regular rubber though, I have a lot of confidence in the Nitto 555RII tires that I am running.
And the new nameplate should be spelled Zephyr, I have my username spelled incorrectly since when I got my first email/internet account way back when, zephyr was taken so I used zepher and have been using it spelled that way ever since.
Old Oct 18, 2005 | 05:17 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
This raises an interesting question......I have (HAD) a 3.42 rear that was put in the car before I got it. The previous owner had no idea. Its supposed to be a 2.73.
I show 190K on the odometer.
I have no idea if the speedo was changed or not (prob not) when this was all changed.
Wondering how much mileage I really have.....more or less than what I show?
Old Oct 18, 2005 | 07:19 PM
dr1's Avatar
dr1
Engine: 305 TBI
your mph will be high if the speedo gears are for a 2.73
so, of course your mileage will be also
do you find people regularly honking at you and flashing there lights and yelling?? if so your speedo gears may be off, they probably are not admiring your car
Old Oct 19, 2005 | 06:25 AM
hah hah
no...usually its the other way around...I feel like I'm usually the one cruising at 65 mph and everyone else is passing me. With 3.42's I was trying to keep the rpms low enough for gas mileage on the highway.
Old Oct 20, 2005 | 10:31 PM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
i just fragged my richmond 4.10s. i have an auto though. havent decided between 3.42's and 3.73's yet. i mostly just drive it around town, no drag racing, but i have a lot of fun with it on the street.
i liked the acceleration of the 4.10s, and i could deal with the high revs on the highway and lower top speed, but i couldnt stand first gear. it was basically just a tire spinning gear. if i was stopped in 1st, and got on it, basically i was hitting 2nd at about 10-15 mph. how much more "usable" would first be with 3.73's?
the difference in highway rpms will be about 300 less rpm for each step lower right?
Old Oct 21, 2005 | 10:27 AM
vernw's Avatar
Before I went to my 4.10 9", I had a factory 3.42 in my 91 'Bird with a WC T-5. At 70mph I was pulling like 2100-2200 RPM IIRC. That would only be a 400-500 RPM drop between 4.11 and 3.42
Old Oct 21, 2005 | 11:01 AM
okfoz's Avatar
I really don't know what everyone is complaing about... I only run something like 2500 RPM at 75 Mph... My old 67 Buick Riv runs 3000 RPM at the same speed, and its a Big Block...
John
Old Oct 21, 2005 | 11:04 AM
1meanGTA's Avatar
t56's cruise at 70 around 1300 rpm
my neighbor has an old avanti ii with a hopped up carbed 350 and a t56, that things nice, even if it is a bit goofy looking. its so smooth on the highway. i'd blow his doors off though
Old Nov 2, 2005 | 05:55 PM
Zepher's Avatar
update:
I am actually getting better fuel economy than I thought.
Did 2 long trips in the past week (160miles round trip for each one, so not exactly that long) and I estimate I was getting around 20+mpg cruising at 3000-3200rpm with a few spirited runs to 4500rpm for a few miles.
Old Nov 2, 2005 | 07:30 PM
savagevulcan's Avatar
Car: 82 Trans Am
Engine: Pro Flo Injected 355
Transmission: BW Super T10 4 speed
Axle/Gears: Ford 9"/3.50
wow 20+mpg, id be jumping if i was getting that!
I get 15 mpg on the very best day and i cruise at 55-60 mph on the highway over here. Also having my top gear (4th gear) at a mere (1:1) and having 3.50:1 gears in my ford 9 inch makes my RPMs fly to 2500-3000 at only 60 mph
Old Nov 2, 2005 | 10:00 PM
6SpeedTA95's Avatar
Car: BMW 335i
Engine: N55 turbo 6
My gosh some of you guys are getting just plain crappy mileage. A stock 305 TPI car with a 5 speed should get 25 to 26 mpg on hwy if its in good tune. With 4.10s I'd suspect somewhere around 18 or 19 mpg on the hwy. Some of you guys are averaging 10, 12 and 14 mpg? On all city driving the WORST mileage I've gotten in my TA was 15 mpg and thats with a 350 LT1 and NOT using 6th gear at all.
If you're getting really bad mileage do a tune, check the exhaust for any restrictions. Something is wrong if you're getting average mileage of 10 or 12 mpg...or maybe you just rape the crap out of your car all the time?
Old Nov 2, 2005 | 10:27 PM
hot92z's Avatar
Car: 92 Camaro Z28
Engine: LB9
Maybe its has something to do with the fact that most of these guys go down the road at 80mph...i get just as good fuel mileage out of my 5 speed as i do as my 4 banger beretta on the highway
Old Nov 2, 2005 | 10:51 PM
6SpeedTA95's Avatar
Car: BMW 335i
Engine: N55 turbo 6
My Trans Am gets better mileage than my Wife's 1996 Rav4, better mileage than her sisters 2003 rav4, better mileage than my old V6 626, better mileage than my friends honda accord V6. In the city I can get 20+ if I baby it, I average about 17 in town though so thats not too horrid. Just seems like you really have to drive them hard to get bad mileage or have 4.11's and drive 80, which would also cause the mileage to drop like a brick...
Old Nov 3, 2005 | 03:31 AM
Zepher's Avatar
I drive my car hard pretty much all the time and cruise at 70-90 on the highway.
Whoboy580
Jun 7, 2011 05:48 PM
Zepher
Jun 22, 2006 12:36 PM
Zepher
Jun 18, 2006 03:01 PM
southerniroc
Feb 24, 2002 10:27 AM
buddman91rs
Apr 28, 2001 11:19 PM
