2-4 band?
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
2-4 band?
Heres the problem: My 700r4 will not shift into OD, and 2nd rearly catches, and if it does it is upwards of 5,000rpm. 1st and 3rd still pull strong. Doing a search, it seems possible that it is the 2-4 band, but I want to make sure before I pull it out and drop it off as I don't know a lot when it comes to the inner workings of a tranny.
Also, what could have caused this? My fluid is beautiful, though there is a slight leak from the tailshaft. This is on (accourding to the friend I bought the car from) a Pro-Build 700r4 w/ a 2,800 stall. TV cable is adjusted properly. Though I do have a B&M shifter. Deffinetely has a corvette (type) servo.
I just started prom tuning with autoprom, and really started gaining a lot of tq w/ the tuning leading up to the tranny problem, so maybe that has something to do with it?
Thank you for any advise
Terrell351
Jun 13, 2021 01:13 PM
Elephantismo
Feb 13, 2019 12:51 AM
no green
Jan 9, 2016 09:22 PM
