View Poll Results: Posi Additive
Yes
54.55%
No
45.45%
Voters: 11. You may not vote on this poll
9-bolt Lube
Old Oct 26, 2005 | 08:08 AM
Kurt04's Avatar
9-bolt Lube
Whats the consensus here. I've seen the threads but can't make heads or tails of it.
Old Oct 26, 2005 | 10:16 AM
ede's Avatar
ede
if you have clutches you need the additive
Old Oct 26, 2005 | 10:29 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I dont use it. if I do the posi slips. I run basica autozone brand gear lube and the posi works now. I know its shot but it works good.
Old Oct 27, 2005 | 12:08 PM
DanS's Avatar
From what I've seen, it seems most people suggest not using the posi additive if you run synthetic lube, but use it if you run non-synthetic. I'll still experimenting with mine (just swapped it in), so I'm undecided.
Old Nov 2, 2005 | 07:43 PM
sleeper383's Avatar
Car: 1984 Camaro Z28
Engine: 5.0L
Transmission: Heavy duty TH700R4 B&M shifter
Axle/Gears: BorgWarner 9 bolt Ratio 3.45
For the Australian build posi 9 bolt you don't need any additive
because the 9 bolt don't have frictionnal clutch in it !
it's a cone clutch rear end..., if your hard on your 9 bolt put in
synthetic gear lube.
Old Nov 2, 2005 | 10:03 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Yep, I run Moble One gear lube.
Old Nov 5, 2005 | 10:47 AM
MY-92-RS's Avatar
Car: 92 CAMARO RALLY SPORT
Engine: 383 sbc w/250 shot of nitrous
Transmission: AMERICAN POWERTRAIN- EXTREME TKX
Axle/Gears: STRANGE ENG. 12 BOLT 3:90 SPOOL
I never use any additive with my nine bolts. It would be a waste of money the cone type differential does not need it. Matter of fact I run 85w –140-dyno-juice oil since my current posi is weak. Helps it out a lot
ctoledo0834
Sep 18, 2015 04:16 PM
6speedIROC
Sep 13, 2015 01:29 PM
64Chief
Sep 12, 2015 08:05 AM
Randomtask2
Sep 7, 2015 05:06 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
