rear end woes, round 2
Old Oct 31, 2005 | 05:10 AM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
well i just got my car back from the gear swap about 3 days ago. set me back almost 1200 bucks, had them hook my nitrous wiring back up, and find an oil leak for me, kind of got hosed.
anyway, the next day, im still hearing something that sounds like it did when the gears had come apart and i would just barely be moving. when i'd pick up speed after they'd shreded, it was really loud and horrible sounding, but at low speeds it just sounded like a sort of clunk, and you could just barely feel it on every wheel revolution. now im getting that again, but there doesnt seem to be any problem once im rolling. its just if im going like 5 mph i can hear it.
im praying its not my gears again, because if it is, the car sits all winter, i can't throw another 1000 bucks at it right now. could the bearings has been screwed up while they had the rear apart, or what else can make a sound like that? its not a loud clunk, you have to turn the stereo down and really listen for it. doesnt sound like anything broken, what it sounds like to me is what non-sealed bearings (like bike bearings) sound like when one of the bearings pops out. are the rear bearings easy to check
Old Oct 31, 2005 | 06:08 AM
ede's Avatar
ede
chancked the trans mount? the rear and axle bearings are easy ti check, except for the pinion would need the preload reset, or a solid spacer used.
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
