how to identify 3.73
Old Nov 1, 2005 | 06:31 PM
camaro430sut's Avatar
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
im gonna be buyin a new rear next wee. the guy claims its got aftermarket ring and carrier in it. supposedly its got a auburn posi and richmond 3.73s. before i lay down any cash for this im gonna pop it open to make sure everything is correct. my question is how do i identify the 3.73s. also is there anything i should check inside the rear when i pop the cover off to make sure its all in good shape.
matt
Old Nov 1, 2005 | 06:35 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Count the number of teeth on the ring and pinion gears...
Check for deposits of metal shavings on the bottom of the axle housing and in the oil. Look around for any visible cracks on the carrier.
Old Nov 1, 2005 | 06:45 PM
how many teeth will be on the ring. ive heard it was 41 but im not to sure.
matt
Old Nov 1, 2005 | 07:01 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Divide the number of teeth on the ring gear by the number of teeth on the pinion.
Old Nov 1, 2005 | 07:09 PM
ok heres my next question. the carrier and gears are installed in the rear and the rear is fully assembled from rotor to rotor. i kno ill b able to count the teeth on the ring but will i b able to see the teeth on the pinion?
matt
Old Nov 1, 2005 | 08:29 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
A very simple method....All gear MFG stamp the gear ratio on the OD of the ring gear. So the gear & pinion count for 3:73 ratio is 41-11.
Old Nov 1, 2005 | 09:12 PM
kewl thanx
UltRoadWarrior9
Apr 28, 2020 10:39 PM
grngryoutmyway
Oct 18, 2016 05:48 PM
JSDaddy189
Sep 26, 2015 03:50 PM
Linson
Sep 21, 2015 01:08 PM
whyt86roc
Sep 10, 2015 10:03 PM
