700r4 TC lockup w/o ALDL connection
Old Nov 3, 2005 | 10:24 AM
wrench_manindy's Avatar
Car: GMC Camaro
Engine: BBC SBC
I did a TPI to carb. swap on a 1986 IROC. I pulled out all wiring and ecm. How can I lock-up the Torque converter by using only the wires that are coming out of the trans. and not going thru the ALDL connector. Thanks for any info that someone can give me. Rob G.
Old Nov 3, 2005 | 10:39 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
+12v on pin A, ground on pin D
Old Nov 3, 2005 | 10:49 AM
Car: GMC Camaro
Engine: BBC SBC
Thanks for your response. But are pin A and pin D in the ALDL or is the connecter at the trans marked with these letters. I cant use the ALDL connecter. Rob G.
Old Nov 3, 2005 | 11:34 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
On the transmission. If you'd just unplugged the ECM and left the wiring under the dash intact you'd still be able to use the ALDL.
Old Nov 3, 2005 | 12:01 PM
Car: GMC Camaro
Engine: BBC SBC
Apeiron, I totally agree with you. When I got this car, the wiring was a total mess. The 3 wires from the trans were already cut. I just need to know which wire from the trans I need to put 12 volts to and which one to ground. Any help from anybody would be great. Thanks Rob G.
Old Nov 3, 2005 | 03:24 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
seiplentz
Aug 19, 2019 06:02 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
gta892000
Sep 16, 2015 12:37 AM
iroczguy86
Sep 13, 2015 02:22 PM
greenyone
Sep 8, 2015 08:41 PM
