trans and coolant
Old Nov 3, 2005 | 04:50 PM
kickasscamaro's Avatar
Car: 1985 camaro z28
Engine: 305 tpi
trans and coolant
would a improper mix of coolant cause a trans to overheat. theres like 80water/20coolant mix.shifts early and really soft after like 10min of city driving. you can feel the heat coming through the center console.
Old Nov 3, 2005 | 05:00 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
Is your engine overheating?
Make sure your fluid levels are correct, check that the cooling lines are not kinked/bent. If possible verify the flow of the tranns fluid.
Old Nov 3, 2005 | 05:13 PM
Engine: 305 tpi
engine isnt overheating, fluids are full, coolant lines look fine
Old Nov 5, 2005 | 06:16 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Check the lines from the tranny to the radiator. Make sure those arent kinked or blocked.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
LittleFranks
Sep 17, 2015 12:22 PM
Bstrang6
Sep 8, 2015 04:29 PM
