tranny swap
Old Nov 4, 2005 | 11:10 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
tranny swap
ok before you guys get onto me about not searching for "how to's" on doing a swap, i'll just say that i found and READ the technical article on the main page about going from an auto to a manual transmission....the problem is, that most of the things stated i have no clue what they look like or anything....i was thinking about doing the swap but i am more of a VISUAL learner...anyone have any pictures of their swap in the making? i need as much help as i can get if i decide to do this...
Old Nov 5, 2005 | 12:02 AM
RestoRoc89's Avatar
Car: 1987 Iroc-Z/1993 Z28/2011 Corvette
Engine: 350 CI TPI/355 CI LT1
Transmission: 700R4/D&D Performance T56
Axle/Gears: 3.27 9-bolt/3.73 10-Bolt
I don't think anyone will ever be able to cover the complete process in a write-up. It seems like everyone encounters something new. It's probably best if you do some research about it. What I started with was just a crappy Haynes manual...it actually had lots of information about the stock T5 setup in the Camaro with a good deal of pictures as well. Another thing that helps is to start getting under the car...look for the various bits of wiring you'll need to modify, locate all the parts and bolts (the bellhousing bolts being nasty) you'll need to remove in order to accomplish the swap, etc. It's not exactly a straightforward thing, but it's not exactly difficult once you're familiar with the car. In my case, tearing every single nut and bolt from the car turned out to be very educational, and makes doing the swap to a T56 a cinch...I don't suggest you take it that far though There's also a great article about a T56 swap in the Chevy High Performance archives...check this out http://chevyhiperformance.com/techar...148_0502_swap/
Old Nov 5, 2005 | 10:30 AM
BlueZee28's Avatar
thanks alot. I just may have to go pick up a hayne's manual. i've never needed it b/c anything i do with my car i can pretty much do on my own. but this seems to be a bit more complicated
camaro11j
Sep 19, 2018 08:49 AM
gta90
Sep 15, 2015 04:00 PM
spaigo
Aug 21, 2015 07:46 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
