TCI Breakaway TC
Old Nov 8, 2005 | 07:18 PM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
TCI Breakaway TC
Anyone running one of these in their 7r4/4l60E talk to me. How does it take off from a light under light throttle and how does it take off when you floor it ? Already searched isn't a whole lot on the board about this specefic convertor. Thanks,
Bill E.
Old Nov 9, 2005 | 09:10 PM
Jetmeck's Avatar
anybody ?
Old Nov 15, 2005 | 05:18 PM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
I've learned that when it comes to converters, you get what you pay for. Cheap converters don't drive as well and tend to generate more heat that a higher priced unit. I haven't used that particular converter, but I wouldn't expect to much from it. Personally, I prefer Edge.
Old Nov 15, 2005 | 05:20 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I'm looking for a new TC too and I haven't heard many good things about TCI. I think a B&M is probably gonna be my next move.
Old Nov 16, 2005 | 06:05 PM
86TA355SR's Avatar
Car: 88, 89 & 91 GTA
Engine: 355 Super Ram/350
Transmission: TH-375/700R4
Axle/Gears: Currie Ford 9"/3.70
I bought a TCI unit a long time ago. As the previous post stated, you get what you pay for. Wasn't happy with it. Saw no change in the ET or the drivability.
Bougth an Art Carr TC after that. Yeah, it cost a lot more, but man, what a difference it made in the car. I highly recommend them, I have put it through a lot of abuse and overheating a few times due to other tranny problems, and it is still functioning perfect. What a great product.
Just a thought.
Old Nov 16, 2005 | 07:43 PM
Pro Built Automatics's Avatar
The TCI & B&M torque converters are not worth the headaches & money it can cost.
Old Nov 17, 2005 | 08:38 AM
Jetmeck's Avatar
K, have read a lot of your stuff here and you seem to know what you are talking about. So could you recommend a TC for the 7r4
that is rated to stall at 2400-2500 yet tight under light throttle
city driving without breaking the bank. Working with a 89 GTA
5.7 at about 380 fwp, 3.27 gears. You think that would be too high a stall for a street driven vehicle, I'll gladly sacrifice SOME stall speed to keep things in the tranny happy and cool ( cooler added) . Most time spent cruising, don't want any slipping. Thank you,
Bill
Old Nov 17, 2005 | 04:09 PM
The Edge 9.5" lockup torque converter is what I would recommend here. You can get the stall you want & have it not be slippery. These units do not present heating problems. I and many others have had good success with these units. These units weigh about 15-17 pounds less than the stock TC, and are much easier on the drivetrain. Another added benefit is that they multiply torque at a higher ratio. I have seen 3-6 tenths knocked off, and gains in the mph, in the quarter mile, with these TC's.
Old Nov 17, 2005 | 04:49 PM
Jetmeck's Avatar
Thank you, know if these come with a lock up option ?
Old Nov 18, 2005 | 08:47 PM
All of the Edge TC's are lockup, unless you order it otherwise.
Old Nov 18, 2005 | 11:22 PM
Jetmeck's Avatar
Thx for the tip, spoke with a salesman at Edge. They are claiming the most efficient coolest running convertor on the market. Also claiming the MOST torque multiplication on the market. They are claiming a larger than stock drop in rpm at lockup, I don't understand how but that would be great. Several hundred dollars below the ViG. 1 year warrantee. What's not to like. Thx.
P.S. Also claiming better mpg due to increased efficiency.
Old Nov 19, 2005 | 05:46 AM
" They are claiming the most efficient coolest running convertor on the market. Also claiming the MOST torque multiplication on the market." I agree with this, as I know how they are built. "They are claiming a larger than stock drop in rpm at lockup, I don't understand how but that would be great." This really has nothing to do with the torque converter, but the pwm being eliminated in 1995 & later vehicles, when using the Trans-Go Shift kits.
Old Nov 20, 2005 | 06:03 AM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
What's pwm? I looked them up too b/c I have been wanting the breakaway for my truck....however, they said they recommended a STR is 2.5 at 2600 brake stall but what would be good for a 4100 pound truck.... but I was thinking around 2.2 with the same stall? Explain the difference if you don't mind about how it would effect a 4100 lb truck and which is better? Thanks.
Old Nov 20, 2005 | 06:04 AM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Also, would this 9.5 inch converter work for a stock flywheel that a 12" converter has been on?
Old Nov 21, 2005 | 01:15 AM
PWM (pulse width modulation) is GM's way of making things smoother at light to medium throttle openings with the torque converter clutch coming on & off & on & off, etc. The Trans-Go Shift kits, eliminate the on & off of the clutch (pwm). The clutch is now on or off, depending load & throttle opening. This eliminates much of the torque converter clutch wear, and lowers the fluid temperature a little. By balancing the rotating parts better, and using better shock absorbing motor & transmission mounts, you would not need the PWM, and its associated problems.
Old Nov 21, 2005 | 01:26 AM
Jetmeck's Avatar
GM only used PWM in 95 up ?
Old Nov 21, 2005 | 09:02 PM
Coach Hawk's Avatar
Yes, PWM is '95 and up. '94 down is non-PWM.
Old Nov 28, 2005 | 11:36 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
So, is a STR of 2.5 good for a 4100 lb truck or would I want a little less?
Old Nov 30, 2005 | 08:03 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
bump
84LsxZ28
May 17, 2020 02:21 PM
roysatikas
Sep 7, 2015 08:08 PM
Eric-86sc
Aug 24, 2015 09:01 PM
Rokshocka
Aftermarket Product Review
Nov 23, 2001 01:29 AM
CamaroX84
Car Audio
Nov 22, 2001 05:11 AM
