What is input sensitivity????
Old Nov 16, 2001 | 08:46 PM
CamaroX84's Avatar
On my Kenwood amp, there is a **** for input sensitivity. What is this? Should I mess with it? Also, my amp does not have anything to set gain with. Why wouldn't it? Thanks.
1984 Camaro Sport Coupe - Rebuilt 355 S/D TPI L98, Crane 2032 CompuCam, Crane adjustable fuel pressure regulator, MSD Blaster coil, custom burned PROM, stock TPI intake, Accel 24# injectors, gutted air box with K&N filters
F41 Suspension Package, 700R4 Tranny, TCI Breakaway torque converter, 3.27 Posi Rear
Hooker Shorty Headers, Catco High-Flow 3" Cat, Flowmaster 3" American Thunder Cat-Back
Best 1/4 Mile Run:
13.847 @ 95.91 MPH
1992 1LE B4C Police Camaro RS - 305 TPI 5-Speed
Old Nov 17, 2001 | 01:46 AM
OldOneEye's Avatar
Car: 1997 Nissan 200SX SE-R
Engine: 2.0 Liter SR20DE
Transmission: 5 Speed
I have always had a hard time explaining this.
For the most part, the gain is kind of like adjusting your fuel/air mixture with a computer. Once its set to your motor (or speakers) it shouldn't be changed. Same with the gain.
The volume control on your car is like the gas pedal.
Some guys try to use the gain as a gas pedal.
Some amp don't have it because they just keep going until the over drive the input. Its a one size fits all approach.
Juan
Coming soon, CES report 2002 at Sound Domain www.sounddomain.com
Old Nov 22, 2001 | 05:11 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
the input sensitivity on the amp is the same as gain.
Set the input to the lowest setting, put your head unit volume all the way up and then start raising your input level on the amp till it's as loud as you want it, this way you won't have to worry about frying your amp or your sub(s), sometimes though, some recordings are louder or lower so try and tune it with a louder recording or a test CD. This is the safest way to keep your system safe.
WS6 Trans Am.
View My Ride @ thirdgen.org
cheesehomer
Dec 31, 2015 08:48 AM
jbates346
Oct 21, 2015 01:50 PM
Linson
Oct 1, 2015 09:50 PM
83ho87gn
Sep 24, 2015 08:58 AM
83 Crossfire TA
Sep 18, 2015 12:01 PM
