I'm leaking a tiny bit of tranny fluid...
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I just pulled my tranny during an engine swap and I noticed the bottom is always covered in tranny fluid. I plan on changing the gasket, but should I do anything else while I'm in/under there? Upgrade and cheap/easy parts, etc.
Car: 85' Z28
Engine: 383 roller
Axle/Gears: Ford 9" 3.70
Change the fillter, make sure your pan isn't bent, and maybe install a new mount since your there. I've also been thinking about tapping a hole for a temp gauge, and it would be the perfect time to do it even if you don't install one right now.
Car: 88 GTA "Cocaine"
Engine: 350 tpi
my trans was doing the same thing. replace the detent cable gasket and the dip stick gromet. you should be able to get these at the dealer for under 5 bucks
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
I started using a polishedcast aluminum pan on some of my builds. It is an offshore pan but seems to be great quality. Built in drain plug, polished aluminun, rubber gasket and stainless bolt. The pan is rigid and the raids are nice and flat. They cost about $60 and make a nice addition.
