I was amazed to find out what transmission was in my car
Car: 1986 Z28
Engine: 305ci
I was researching drive and driven gears for my car. In the process I found out that my 1992 has a 4L60 tranny and not the TH700R4 like I thought.
Is this odd?
Also, in the GM system, it looks like these are the same except for the numbers.
OR
The 700R4 does not use a VSS like the 4L60 does.
This should be a good conversation!!!
Is this odd?
OR
Car: 1986 Z28
Engine: 305ci
Originally posted by 84z28350
Its not the first time one has been swapped into a 3rd gen...
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The new naming scheme is more consistent and systematic. The first digit indicates the number of forward gears, the second letter describes the orientation (longitudinal or transverse), the final digits indicate the nominal strength, and an E is appended to indicate electronic instead hydraulic control.
Do we know if GM changed anything?
They changed the name. Nothing else. The actual parts are all the same.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Originally posted by sofakingdom
Yes, we know that.
Yes, we know that.
Car: 1986 Z28
Engine: 305ci
Yes, we know that.
Yes, we know that.
GM is nuts!!
Car: 2006 Silverado 1500
Engine: 5.3L
these guys are correct. the 700R4 recieved a name change in 1988 to the 4L60. this was simply done because this is how GM was to name their transmissions in the future.
Example: 4L60
4=4 forward gears
L=longitudinal (rwd)
60=torque rating system GM made for themselves
Another example: 4T60E
4=4 forward gears
T=transaxle (fwd)
60=torque rating
E=electronicly shifted
Example: 4L60
4=4 forward gears
4=4 forward gears
T=transaxle (fwd)
60=torque rating
Car: 1986 Z28
Engine: 305ci
Example: 4L60
4=4 forward gears
4=4 forward gears
T=transaxle (fwd)
60=torque rating
Example: 4L60
4=4 forward gears
4=4 forward gears
T=transaxle (fwd)
60=torque rating
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
Example: 4L60
4=4 forward gears
Example: 4L60
4=4 forward gears
Car: 1988 IROC-Z
Example: 4L60
4=4 forward gears
Example: 4L60
4=4 forward gears
Car: 85 camaro z28
Transmission: T56 6 speed
Axle/Gears: 3.27 borg warner 9 bolt
i learned a bunch also from this. but does anyone know what the 700r4 actually stands for just out of curiousity.
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Example: 4L60
4=4 forward gears
4=4 forward gears
T=transaxle (fwd)
60=torque rating
Example: 4L60
4=4 forward gears
4=4 forward gears
T=transaxle (fwd)
60=torque rating
4-speeds, Longitudinally positioned, 6000 lbs. GVW Electronically Controlled
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
never knew the 60 was 6000 gross vehicle weight
thats cool to learn
thats the only thing i had no idea on
otherwise all this is old info
good job
thats cool to learn
good job
Engine: 5.3L
Originally posted by AJ_92RS
Close....
Close....
colton_carlson
Mar 8, 2019 12:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
