camaro and s10 same axle or no???
Subscribe
Nov 18, 2005 | 02:51 PM
Hi,
I have s10 axles that look to be 28 splines,,,,, are they the same as the camaro axles?? would they fit?
Reply 0
Nov 18, 2005 | 02:54 PM
No.
They are exactly the same, except they're different. Different length.
If you have an axle stretcher though, I believe you can stretch them just barely enough to make them work.
Reply 0
Nov 18, 2005 | 04:19 PM
lmao!
thats pretty much the same line we use on the newbies at work, If they make a hydraulic hose too short we tell them to go fing the hose stretcher, they spend a good half hour looking for it before we fill them in on whats going on!
Reply 0
Nov 19, 2005 | 07:47 AM
lol... i am somewhat amused by threads like these. hehehehehe
Reply 0
Nov 19, 2005 | 11:00 AM
Quote:
Originally posted by 84z28350
lmao!
Ask them to;
1) Go get a fallopian tube.
2) Go get me a bucket of bulkhead remover.
3) Go get a bucket of steam.
Then go ask the to get a chain stretcher (those are real).
Reply 0
Nov 19, 2005 | 08:32 PM
If it was only that easy, all the S10 axles would have disappeared years ago. The only axles that will fit into a third gen housing are from another third gen or aftermarket axles. Aftermarket third gen 28 spline axles are only $125 - $150 each.
Reply 0
Nov 21, 2005 | 10:34 AM
yah ok i have a 1 set of s10 28 spline axles and i have 2 sets of camaro 26 spline axles.....that sucks
ok so maybe ill just weld in 2 more splines on each axle and i should be good....noo wait ill just cut the ends of the s10 axles and put them on the camaro axles... what will work good. JK
Ok on a serious note why are the 28s better then the 26's anyhow??
Reply 0
Nov 21, 2005 | 10:36 AM
Quote:
They are a larger diameter axle. = stronger
Reply 0
Nov 21, 2005 | 10:50 AM
ok yes that would do it... thanks!
Reply 0
Subscribe
