gear vins
Car: 89 Iroc
Engine: 5.7tpi
Axle/Gears: 9 bolt posi w/ 2.77s
gear vins
can someone give me the numbers or letters on the VIN to help me figure out what gears i have in my '89 iroc? im wanting to get new gears and need to know. thanks
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
if you still have the rpo codes that will tell you otherwise you need to open the rear end and divide the number of teeth on the ring gear by the number of teeth on the pinion. Or, you can find the numbers stamped on the ring gear and divide those by each other.
Engine: LT1; LT1
UltRoadWarrior9
Sep 2, 2015 08:24 PM
