Fluid in new tranny is pink...
Old Nov 3, 2005 | 12:58 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
I picked up a new 700r4 (new to me, but used) and i was just checking it out or whatever. and i got some liquid out of it and its like pink. it looks like cloudy or something. is this bad?
Old Nov 3, 2005 | 02:48 PM
Sounds like water in the fluid.
Probably not good; maybe bad.
I guess it depends on how the water got there.
Old Nov 3, 2005 | 03:43 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Drain it before you use it and hope it got in there while sitting.
The water that is.....as it will eat up the clutches.
Old Nov 3, 2005 | 07:27 PM
ZZ4 86 Z28's Avatar
yea i know its been sitting for a little while. the guy told me to drain it and get a new filter just in case. its pretty open, i mean i can just look into it from the top (where there should be screws at some point i believe).
Old Nov 6, 2005 | 08:09 PM
RestoRoc89's Avatar
Car: 1987 Iroc-Z/1993 Z28/2011 Corvette
Engine: 350 CI TPI/355 CI LT1
Transmission: 700R4/D&D Performance T56
Axle/Gears: 3.27 9-bolt/3.73 10-Bolt
And now you're trying to sell this tranny to someone else? How come? Did you determine there's a problem with it? If so, I think it would be decent of you to mention that in your classified ad. If you don't, it will greatly serve to discredit you.
Old Nov 6, 2005 | 08:21 PM
ZZ4 86 Z28's Avatar
i mentioned it to the person who is buying it and picking it up sunday. we tried to take out the old tranny and we gave up after realizing that even after removing the cat and y pipe we would need to go even further by removing the header and my friend did not want to be responsible. so we slapped all my old stuff back together and i have not even touched the new one yet. i figure if i am going to be dishing out a lot of money to get a trans put in, I might as well go with a brand new one thats built up with a warranty. Im really not trying to screw anyone. if anything im screwing myself by not wanting to give the person i bought it from any troubles by trying to give it back to him. three people pm'ed me and i told them about the pink fluid. i am also including a brand new filter/gasket set and new fluid. good job looking out for people though, I always appreciate when people do that when I am trying to buy something.
Old Nov 6, 2005 | 09:06 PM
RestoRoc89's Avatar
I'm glad to hear you've been thorough with the buyer Without prior experience and the proper equipment, swapping a tranny can be a big job (but also a great learning experience). Good luck getting it sorted out.
Old Nov 6, 2005 | 09:11 PM
ZZ4 86 Z28's Avatar
Ive been making lots of deals all the time on line with all kinds of electric guitar and amp stuff, so I know all the implied rules and stuff and to let the buyer know EVERYTHING. I let him know the name of the person I bought it from and all the info he gave me, etc. if it werent for the long tube headers the previous owner put in my car, we prob couldve gotten it in fairly easily, but oh well, if they didnt wanna mess with anything else, thats their decision.
Old Nov 14, 2005 | 02:22 PM
ZZ4 86 Z28's Avatar
ok nevermind im keeping. what should i do with it off the car to give it a nice cleaning?
Old Nov 22, 2005 | 12:57 AM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
there is definately water in the trans mixed with the fluid. The problem is the trans cooler in the radiator. the water pump is actually recirculating the fluing through the engine. empty the block and you will find the pink stuff everywhere. You need to fix the problem quickly so teh valve body and the separator plate don't start to rust from the water. I know this from personal experience.
Old Nov 22, 2005 | 02:19 AM
irocbarry's Avatar
Car: 85 IROC
Engine: L-69 305
Transmission: T-5 manual
why do you say its the trans cooler?
when he bought the trans it had been sitting with the top of the case open, so more then likely the water is rain. the tranny has never been in his car, so why would his motor have pink stuff in it
Old Nov 22, 2005 | 05:21 AM
1981LT1's Avatar
Engine: LT1; LT1
That does make sense. I guess I should read through the question completely before I answer.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
HoosierinWA
Oct 7, 2015 10:15 AM
bjpotter
Oct 4, 2015 07:48 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
