what oil to use with 10 bolt 4.11 posi
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
I'm not sure at all about filling these rears or how to do it, like how much to fill them up/what to use. Could someone please help me asap today .
Car: 88 FORMULA / 88 IROC
Engine: 355 / 355
Transmission: T5 / TH400
Axle/Gears: 10 Bolt-3.73 / 9"-3.90
Pull the 3/8 square plug on the passengers side and fill with a good gear oil like Red Line or Lakewood BFL should take around 2 bottles depending on your cover fill it until the oil just begins to come back out of the fill hole. Also make sure the car is as close to ride height level as possible when you do this to ensure an accurate fill. If you use the RedLine or Lakewood BFL with the limited slip additive there is nothing else to do if you are using a standard gear oil you will need to add limited slip friction additive before you begin filling up with the gear oil..
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
If the rear end is really low on oil or you are changing it, after you fill it back up, take it for a ride, and then recheck the level. I had to add some (not much).
hectre13
Dec 11, 2023 08:14 AM
ambainb
Apr 25, 2016 09:21 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
knight72
Aug 10, 2015 09:32 PM
