stripped out the INSIDE threads on my tranny
Old Nov 22, 2005 | 05:28 PM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
i was changing my tranny mount earlier and i tightened the bolt that goes through the mount into the tranny itself, stripped the threads inside the transmission. now what? they aren't completely stripped, but you can see by looking at it its not at tight as the other side. do i have any options besides tapping out the hole and using a bigger bolt?
Old Nov 22, 2005 | 05:54 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
heli-coil
Old Nov 22, 2005 | 06:25 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Originally posted by 1981LT1
heli-coil
Yep.
Old Nov 22, 2005 | 06:57 PM
1meanGTA's Avatar
where do i get that from? is that better than a plain old craftsman tap and die kit?
Old Nov 22, 2005 | 08:06 PM
zcamaro28's Avatar
Car: 1984 camaro z28 / 1994 jeep wrangler
Engine: 383 stroker / 4.0 HO straight 6
Transmission: built 700r4 / 5 speed
o deff helicoil that sumbitch u can get it at any parts store and its easy to put in we had 5 rear motor plates (darn magnesium) and we put the helicoil in there and its still in there
Old Nov 22, 2005 | 09:37 PM
1981LT1's Avatar
Engine: LT1; LT1
i know for sure that NAPA sells the kit for it. Take them the bolt and they can match the threads. Be aware that the kit is going to be around $30.00!
Old Nov 23, 2005 | 05:20 AM
ede's Avatar
ede
there are some inserts that don't require special taps and such. not sure if you have enough metal there to use one or not but it wouldn't hrt to see what you can find. if you have access to an industrial fastener supply you should have your pick to several inserts. 30 dollars would be a great price for a heli coil kit. i bought one few weeks ago for work, and it was an off brand, and the cost was over 50 dollars.
Old Nov 23, 2005 | 05:10 PM
1meanGTA's Avatar
ok i got the helicoil. brilliant design. im ok to use high strength thread locker inside and out right?
Old Nov 23, 2005 | 05:16 PM
zcamaro28's Avatar
Try buying the complete kit of every size bolt. From the msc catalog. Needless to say i have a small fortune in heli coil and it is actually the name brand.
Old Nov 23, 2005 | 05:54 PM
1981LT1's Avatar
Engine: LT1; LT1
just put the thread locker on the outside of the helicoil and thread it in. Make sure you knock out the little tang inside the helicoil.
Old Nov 24, 2005 | 06:37 AM
1meanGTA's Avatar
what do you mean knock it out? like cut it out?
Old Nov 24, 2005 | 07:07 AM
ede's Avatar
ede
i like the keen-sert, or king-cert not sure which, takes a standard tap and doesn't reqire any special tools to install. it does need a lot of metal around the hold ,i tihnk a 1/4-20 insert takes a 1/2-13 tap. use to put inserts in the case of the little B&S engines back in my karting days before the stripped because you knew at some point they were going to strip.
Old Nov 24, 2005 | 07:10 AM
1meanGTA's Avatar
shouldnt be a problem anymore, i got a torque wrench about a year ago, swapped the tranny mount before then and kind of just guessed at 35 ft lbs. i guess i didnt guess very well.
Old Nov 24, 2005 | 11:23 AM
1meanGTA's Avatar
hmmm. i broke off 2 of my crossmember bolts taking it off to get it out of the way to drill for the heli-coil. then, trying to take them out after having been awake about 30 hours and worked 12, drilled in the crossmember bolts offcenter with my bolt remover. i dont think i'm going to get either of those out. im thinking about just putting it back together with what i have now, taking it to a shop and having them pull the bolts for me.
what should i expect, how difficult will it be for them to remove them? im expecting a 50-75 dollar bill for it, is that about right? any other options for me to get them out?
Old Nov 24, 2005 | 11:52 AM
AaronIROCZ's Avatar
Moderator/TGO Supporter
In my experience the only way I found that fixes the broken cross member bolts was to cut the floor out right above the nuts, drill out the welds that hold the nuts in and weld in new nuts. But that works for me since I am replacing the floor plans . It might not work for you, Just an idea.
Old Nov 24, 2005 | 11:55 AM
1meanGTA's Avatar
wow, i dont want to do all that.... dont shops have a simple way of removing broken bolts?
Old Nov 24, 2005 | 08:10 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
Nope. Most shops do everything they can to avoid breaking them.
We have all been down this road. Removing the bolts and restoring the threads can be time consuming and expensive. Nothing left to do , except write the check. I would not lose sleep over it. Time and money will fix it.
Old Nov 28, 2005 | 05:47 PM
1meanGTA's Avatar
i decided to just drill them out myself after getting a couple of quotes on labor. it was looking a little to easy and i like a challenge, so i thought i might just drill out some of the threads on the nut on the other side.
what now? are those welds sturdy enough i could actually drill out the nut and put a helicoil in that? is there any other way to change that nut without cutting a hole in my floor?
InfinityShade
Sep 5, 2015 06:38 PM
WIzmo
Aug 30, 2015 02:30 PM
Thornburg
Aug 25, 2015 01:46 AM
g.l.mos
Aug 22, 2015 12:02 AM
TreDeClaw
Aug 14, 2015 06:58 PM
